Page 4 of 8
Re: FAVAR add-in
Posted: Wed Feb 14, 2018 12:55 pm
by Bens
hey dakila,
I could solve the problem on my own. Apperently this only appears when using eviews 9. In eviews 10 everything works perfectly fine. Another very important question is how you handled the forecast error variance decomposition. I know how it works in standard VAR models but I never did that in a FAVAR since the variables arent directly included in the VAR. Am I right to suppose that you cant just multiply the standard Forecast error variance decomposition by the factor loadings? In the BBE paper the formular is quit confusing, since its seem like this is exactly what they did. How did you handle that :)
Best,
Ben
Re: FAVAR add-in
Posted: Thu Feb 15, 2018 12:23 am
by dakila
vardecx=lam.@t*varf*lam ' variance in x's due to monetary shock vardecxtot=lam.@t*varftot*lam ' variance in x's due to all commom factors vardecxcom=@ediv(@getmaindiagonal(vardecx), @getmaindiagonal(vardecxtot))
Re: FAVAR add-in
Posted: Fri Feb 16, 2018 3:03 am
by Bens
Thanks for sharing parts of your code. So basically you calculated the part the forecast variance of the variable explained by the monetary policy shock relativ to the variance explained by all factors and the monetary policy shock? Thanks for your help and providing an insight into your code :)
Ben
Re: FAVAR add-in
Posted: Fri Feb 16, 2018 5:30 am
by Bens
Hey its me again,
we are struggling with heteroskedasticity in our favar and we know that there are bootstrap meausures which account for that when constructing confidence bands. Could you tell/show us, which bootsstrap measure you applied?
Re: FAVAR add-in
Posted: Sun Feb 18, 2018 3:36 pm
by dakila
see Killian (1998).
Re: FAVAR add-in
Posted: Mon Apr 09, 2018 10:41 am
by jaromir.gec
is it possible to obtain the IRF for a variable which is only differenced and not log-differenced (has negative values) using your add-in, please?
My second question is connected with the IRF interpretation. Is the y axis in standard deviations of original variables or in standard deviations of variables trasformed to exhibit stationarity (for example: if the variable is log-differenced, is the y-axis unit of IRF standard deviation of level or standard deviation of log of the original variable)? Thank you very much.
Re: FAVAR add-in
Posted: Wed Apr 11, 2018 8:39 pm
by dakila
It now includes the first difference option (code=2).Please update the favar add-in.
Y axis is in standard deviation unit (0 mean, 1 variance) of untransformed variable.
Re: FAVAR add-in
Posted: Fri Apr 13, 2018 11:38 am
by jaromir.gec
Thank you very much for your reply. Unfortunately, I can't update the add-in anymore as it says: "Could not open file due to: unknown error." I tried both Eviews 9 and 10 at work. At the same time, I can update other Eviews add-ins without any issues, so it seems that this error is specific to FAVAR addin only at the moment.
Re: FAVAR add-in
Posted: Fri Apr 13, 2018 11:47 am
Try now.
Re: FAVAR add-in
Posted: Fri Apr 13, 2018 11:53 am
by jaromir.gec
It works now. Thank you very much!
Re: FAVAR add-in
Posted: Wed Nov 28, 2018 12:07 am
by uurak
Hello;
Is it possible to see factor loadings or where can be found? And is it possible to estimate VAR with dummy variables or exogenous variables?
Thanks..
Re: FAVAR add-in
Posted: Wed Nov 28, 2018 8:05 am
by dakila
You can do this manually
Re: FAVAR add-in
Posted: Thu Nov 29, 2018 12:05 am
by uurak
Hi Dakila;
Thank you for the quick response. But where exactly can I find the loadings? I try to classify the factors but I did not find that which factor is affected by which variable. Thanks.
Re: FAVAR add-in
Posted: Thu Nov 29, 2018 2:30 pm
by dakila
For example:
equation eq.ls series01 _facrot1 _facrot2 _facrot3 ffr
Re: FAVAR add-in
Posted: Tue Jan 29, 2019 7:19 am
by abdhut123
Hi everyone, can I order the y series before the factors.....in estimating FAVAR....
