HDecomp (historical decomposition)
kartikanindya
Re: HDecomp (historical decomposition)
Postby kartikanindya » Thu Aug 04, 2016 4:50 am
Hi everyone,
I also want to use this Historical decomposition add ins on the structual shocks of oil price.
So, I have 4 structural shocks : oil supply shock, aggregate demand shock, oil-market specific demand shock, and other shock.
As discussed before, the result of the add-ins is histmat matrix shows 20C. However, I am confused on how translate this result to graph.
I read this thread and find that C1-C5 represent the first shock, and so on.
Do I have to create graph manually by adding C1-C5 into Shock 1, etc?
Thank you. Really appreciate your answer.
Hi, I attached the my workfile, so the output of this addins is histmat01, then how to create graph from it? Thanks
hisdoc.wf1
(115.76 KiB) Downloaded 1169 times
wilshire
Postby wilshire » Fri Aug 30, 2019 11:53 am
Hello all,
Within the attached workfile, I run the command
var_1.hdecomp(hist=ma1,g)
but I do not obtain a matrix object called ma1. I am using Eviews 10. It worked in Eviews 9.5.
Could you please help?
test_hdecomp.WF1
(375.32 KiB) Downloaded 1283 times
Postby EViews Gareth » Fri Aug 30, 2019 1:42 pm
The built in procedure, http://www.eviews.com/help/helpintro.ht ... 23ww235718, has taken over the hdecomp proc and has different options/syntax.
If you want to continue to use the add-in you will have to give it a different proc name.
Return to “Add-in Support”
