Removing NA values from a series in the workfile
misscats
Re: Removing NA values from a series in the workfile
Postby misscats » Tue Apr 01, 2014 11:49 am
Yes, both the wfopen and import commands have a range statement to select the range of cells to import.
Many many thanks. But back to my initial question: how to write the code for the below action?
Proc->Contract Current Page
then set the sample to "if X<>NA" where X is the series with the NAs.
Postby EViews Gareth » Tue Apr 01, 2014 11:57 am
Pagecontract if x<>na
misscats
Postby misscats » Wed Apr 02, 2014 3:49 am
Thank you Gareth. Thanks for inspiring me. I also try to code in a different way and it also works:
for %sheet 1 2 3 %range = %sheet wfopen "C:\Users\...\Data.xlsx" range=%range @keep smb hml mom dummy1 ret @selectif ret<>na next
vasudhak
Postby vasudhak » Sat May 24, 2014 3:37 am
I am using Eviews 7, I am an amateur. I have stock return series of 45 companies in 5-day per week format over 150 days. I want to establish there GARCH model, but Eviews prompt me saying that we cannot run MA models on discontinuous series.
I have some NA values in my stock return series, some are missing data and other are government holidays. Can you please suggest how to deal with these NA values and establish GARCH model hence.
Hammedm
Postby Hammedm » Wed May 05, 2021 4:08 pm
Hi all,
@all if y<>na, is bring error (@ALL is not defined or an illegal command in eviews 11). Could you help pls.
Thank you.
Postby EViews Gareth » Wed May 05, 2021 4:17 pm
What’s the context!?
