BPTest (Breusch-Pagan LM test for random effects)
Re: BPTest (Breusch-Pagan LM test for random effects)
additional information, i used eviews 7, add in lm test already download, equation: group01
thanks
thanks
EViews Esther
The BPTest addin will work from the equation object. Please specify your equation first and then run this addin.
Dear All,
Why does this test so long? It takes up my processor and memory but crashes in between without displaying results. I have test it with a very small data and it works but my panel data is 142 countries, 17 years, 6 variables. As I write this, Eviews is still processing and displaying not responding. My Eviews is 7.1, and computer is Core i5, 64bit Windows 7 and 8 GB Ram, how much more does it require?
It couldn't hurt to apply the free updates to bring your version uptodate.
Great... It works perfectly after updating to Eviews 7.2. Thanks alot and keep improving this remarkable software.
stephaniega
Hello!
I have a fixed effects model using panel data. I want to test if the residuals are normally distributed and that they are not autocorrelated. I have not found a test for this when using a fixed effects model.
Any ideas? And if there is not a function to do this in the program, is there any way to do this manually?
Sincerely
Stephanie
Sincerely
Stephanie
when I run the Breusch-Pagan add-in for the object "Equation: MQOAGRUPADO" in the attached file I receive the following message:
Matrix or vector given non positive dimension in “MATRIX(0,5) _D1T01”
Could you help me with this problem?
Thanks,
Moises
Thanks,
Moises
- tabela dados brics_forum.wf1
- (54.9 KiB) Downloaded 2669 times
EViews Esther
Please reinstall this addin and do the BP-test again.
Thank you. Now it works.
Erikvanaal
I have a question concerning the add-in BPTest. I specified my equation but then when I want click on: Add-ins--> Breusch Pagan Random Effect LM Test, it gives an error saying: Procedure can only be run from Equations estimated by list. What does it mean? Thanks in advance!
Edit: I use Eviews 8
You must specify your equation as a list of variables, not as an expression (e.g. Y X1 X2 C, rather than Y=C(1)*C(2)*X1)
Erikvanaal
Ok thanks now it works. However when I do the test I get an error identical to what other forum members also have. It says: 'Out of memory in .....' Does it mean that the memory problem is also not fixed for eviews 8 and that I should use older versions? If so, which version do you suggest then?
EViews Esther
This implies that your dataset is too large so that the SLM test cannot be performed. I would suggest to exclude the SLM test from the list for now.
I will figure out how to deal with the large dataset problem.
Could you tell me, please, where I should write such expression as Y=C(1)*C(2)*X1 for getting appropriate results of BPTest?You must specify your equation as a list of variables, not as an expression (e.g. Y X1 X2 C, rather than Y=C(1)*C(2)*X1)
Basil Oberholzer
Dear All,
I am running a panel data model with EViews 10. However, when I want to run a Breusch-Pagan LM test for random effects, the software tells me "not available with this estimation method". But I am using normal pooled OLS to test for it without any random effect already being defined. What is wrong?
Thanks for any hint.
