Page 3 of 3
Re: Roll (Rolling Regression)
Posted: Wed Dec 04, 2013 11:20 pm
Hard to know.
Don't include the constant term.
Posted: Tue Feb 04, 2014 2:25 am
by tariqaziz
I have added code in the program to save the S.E. of regression also in the results output. Its working fine.
Posted: Thu Dec 01, 2016 5:15 am
by kkalev
Hello. Running Eviews 9
I believe there is a small bug in the Advanced Rolling Regression with Anchored Start. When the sample is different from the full sample the plug-in will still store estimated coefficients (and other elements) as if the starting point was the first observation in the workfile. I think that the following fix is necessary in advroll.prg at line 268 and after:
if !windowtype=2 then %last = @otod(@dtoo(%start)+!i-1) smpl {%start} {%last} !k= !i
becomes
if !windowtype=2 then %last = @otod(@dtoo(%start)+!i-1) smpl {%start} {%last} !k= @dtoo(%start)+!i-1
Thanks a lot!
Posted: Thu Dec 01, 2016 10:16 am
Updated.
Posted: Thu Mar 09, 2017 3:30 am
by Janys
I'm trying to get the confidence interval in the rolling coefficient graph (and other graphs as well). Does anyone know how to get it? I able to get it with an older version (I guess). But it seems like I couldn't get the confidence interval anymore after I switched to Eviews 9 and re-downloaded the addins. Would greatly appreciate for your help!
Posted: Sun Jun 10, 2018 11:43 pm
by bhavesh
Assuming you have a simple linear regression, you'll have to write out the algebra in a series expression manually. Something like:
series fcast = coef1 + coef2*x1 + coef3*x2
Hi. Can the rolling regression be applied to ARDL bound testing approach (or any other cointegration approaches) in EViews? Eagerly waiting for your response.
Posted: Mon Jun 11, 2018 12:11 am
by enricodace
which methods is suitable to detect multicollinearity under rolling regression? Nither VIF nor correlation plot isn't working for rollings. Any idea please?
Posted: Thu Jun 14, 2018 9:00 am
by enricodace
Dear Gareth,
I have downloaded a rolling add_in.
I did it, it seems working but when i checking results the rolling estimate is just an exact copy of the one with out rolling? what could be the problem and why?
Posted: Sun Jan 24, 2021 1:31 pm
by FraFeMan
Dear Gareth,
Could you please confirm that the version of the add-in "roll" on the website is actually the most updated version, as it is dated 2010?
Many thanks and kind regards,
Francesco
Posted: Sun Jan 24, 2021 3:37 pm
It is.
Posted: Mon Jan 25, 2021 5:40 am
by FraFeMan
Many thanks Gareth.
I run the roll add-in on a single OLS equation with monthly data from 1998m01 to 2014m09, i.e. y=c(1) + c(2)*x + c(3)*z + e, on a window of 36 observations and with 1-step size. Therefore I was expecting the first value of the parameters' estimates, e.g. c(1)_hat, c(2)_hat and so on, to be reported on 2001m01, but instead they are reported on 2000m12, which I believe is incorrect.
Could you please let me know if this is correct and a deliberate coding decision, or I need to fix it in the code (if so, grateful if you could assist me).
Many thanks and regards,
Francesco
Posted: Mon Jan 25, 2021 8:58 am
If your window size is 36, the first regression will run from 1998m1 to 2000m12 (36month), and will thus report its results in the last observation, which is 2000m12.
Posted: Mon Jan 25, 2021 9:44 am
by FraFeMan
Many thanks Gareth for the helpful clarification!
Kind regards,
Francesco
