ERRORHELP
adarshad
Re: ERRORHELP
Postby adarshad » Thu Dec 06, 2018 1:39 pm
ELSE IF( [ eq{!i}.@pval(2) <!pval_C AND eq{!i}.@aic < !aic OR eq{!i}.@pval(3)<!pval_D ] AND [eq{!i}.@aic < !aic] )THEN ', SELECT EQUATION IF XA OR XB HAS PV LESS THAN 0.1 !aic = eq{!i}.@aic !bestlag_a =(!lag_a) ', then store this lag as !bestlag. !bestlag_b =(!lag_b) ', then store this lag as !bestlag.
here i want to select either of the pv values less than 0.1 but having minimum AIC
IS CODE RIGHT ?
adarshad
Re: ERRORHELP
Postby adarshad » Thu Dec 06, 2018 2:03 pm
SECONDLY MY preference is to select values less than 0.1.it should do that and if there are any values than it choose less aic.because here i fear that it tries to make all three conditions true.i;e. if equation has less pvs but aic is greater than aic of a lag which has no pv less than required, it will return no value as no condition is true
EViews Matt
Re: ERRORHELP
Postby EViews Matt » Thu Dec 06, 2018 3:31 pm
There's an error because you've used [] brackets instead of () parentheses to indicate subexpressions.
The combined logic of those three if clauses effectively ignores the p-values. As long as the AIC of the equation is better than any previously seen, one of the three clause conditions will be true. What you also need is a way to record how many p-values (0, 1, or 2) must be less than 0.1 before you consider the AIC. For example, once you've found an equation with one of the p-values less than 0.1, then any future equation with no p-values less than 0.1 cannot be the best, regardless of whether its AIC is better or not (if I understand your requirements correctly). Similarly, once you've found an equation with two p-values less than 0.1, any future equations with one or no p-values less than 0.1 cannot be the best.
adarshad
Re: ERRORHELP
Postby adarshad » Thu Dec 06, 2018 5:40 pm
You got correct in last paragraph.my aim is to find pv less than 0.1 regardless of aic.
I still donot know how to execute it as it includes min aic in it.
Even if I just get two options.either it should select two pvalues less than 0.1 .if no then use aic min for all others .in case there are many pairs for two pv values less than 0.1, it should choose the pair with min ac of multiple solutions of pvs.
I think i donot account for multiple pv pairs less than 0.1 for my question, where i derived that it should look for min aic for lags combinations with pvs.
But instead it there also adds min aic as basic requirement which i donot want.
So solution is first choose min pv less than 0.1 .this is solution i want.if there are many, choose that pv which has min aic
If there are no min two pvs, it should choose min aic.
adarshad
Re: ERRORHELP
Postby adarshad » Thu Dec 06, 2018 5:57 pm
I HOPE YOU can help me in this case because i tried but i am not coming with a code.i want tow pvs less than 0.1 OR ANYTHING;I AM NOT ABLE TO FIT THE MIN AIC IN A RIGHT WAY IN CODE; I WANT IT TO USE ONLY IF THERE IS CONFLICT IN SOLUTION OR THERE IS NO SOLUTION;
please help me in that
adarshad
Re: ERRORHELP
Postby adarshad » Thu Dec 06, 2018 7:38 pm
matrix(5,28) pv matrix(28,30) RESULTS vector(28) aic !maxlags = 4 !bestlag_a = 0 !bestlag_b = 0 !bestlag_c = 0 for !i=1 to 2 !aic_1 = 99999999 !aic_2 = 99999999 !aic_3 = 99999999 !pval_C = 0.1 !pval_D = 0.1 for !lag_a = 0 to !maxlags for !lag_b = 0 to !maxlags for !lag_c = 0 to !maxlags equation eq{!i}.ls Y{!i} c X{!i}A(0 to -!lag_a) X{!i}B(0 to -!lag_b) Y{!i}(-1) X{!i}C(0 to -!lag_c) IF ( eq{!i}.@pval(2) < !pval_C and eq{!i}.@pval(3) < !pval_D ) or (eq{!i}.@pval(2) < !pval_C and eq{!i}.@pval(3) < !pval_D and eq{!i}.@aic < !aic_1 )THEN !aic = eq{!i}.@aic !bestlag_a = (!lag_a) !bestlag_b = (!lag_b) !bestlag_c = (!lag_c) ELSE IF eq{!i}.@aic < !aic_2 THEN !aic = eq{!i}.@aic !bestlag_a = (!lag_a) !bestlag_b = (!lag_b) !bestlag_c = (!lag_c) ENDIF ENDIF EQUATION eq{!i}.ls Y{!i} c X{!i}A(-!bestlag_a ) X{!i}B(-!bestlag_b ) Y{!i}(-1) X{!i}C(-!bestlag_C) colplace(pv, eq!i.@pval, !i) aic(!i) = eq!i.@aic matrix PVALUE = @transpose(pv) results.setwidth 25 matplace(results,PVALUE,1,1) colplace(RESULTS,AIC,21) SHOW RESULTS NEXT next next NEXT
just choose tco options but i dont know how to make skip calculations if pvs are found
i hope to see some help;;i tried all foul things i can imagine but could not;;if else while etc everything but cannot make any solution;;;;
EViews Matt
Re: ERRORHELP
Postby EViews Matt » Fri Dec 07, 2018 10:21 am
You could explicitly record which of those three cases (0, 1, or 2 p-values < 0.1) you're in, and the logic to transition between them, but lets try a little numerical trick. Replace all of the if logic with,
!fake_aic = eq{!i}.@aic - 1000 * ((eq{!i}.@pval(2) < !pval_C) + (eq{!i}.@pval(3) < !pval_D)) if !fake_aic < !aic then !aic = !fake_aic !bestlag_a = !lag_a !bestlag_b = !lag_b !bestlag_c = !lag_c endif
The idea above is to create a score for the estimation, which I've called "fake_aic". The score is based on the AIC, but the score gets better as more p-values are less than the 0.1 threshold. If neither p-value is less then 0.1, then the score will just be the AIC. If only one p-value is less than 0.1, then the score will be the AIC - 1000, which will be better than all the possible scores for an estimation with no p-values less than 0.1. Similarly, if both p-values are less then 0.1, then the score will be AIC - 2000, which is better than all the possible scores for an estimation with one or no p-values less than 0.1. Defining the score this way allows you to preference more p-values less than 0.1 and use AIC as the tie-breaker.
adarshad
Re: ERRORHELP
Postby adarshad » Sun Dec 09, 2018 6:46 am
Dependent Variable: Y1 Method: Least Squares Date: 12/09/18 Time: 14:37 Sample (adjusted): 1/13/2013 12/31/2017 Included observations: 260 after adjustments Variable Coefficient Std. Error t-Statistic Prob. C -0.001191 0.000306 -3.895746 0.0001 X1A(-1) 5.54E-05 1.55E-05 3.563423 0.0004 X1B(-1) 0.005620 0.003237 1.736433 0.0837 Y1(-1) -0.117793 0.056815 -2.073278 0.0392 X1C(-1) 3.02E-12 1.28E-12 2.349282 0.0196 R-squared 0.248544 Mean dependent var 0.001195 Adjusted R-squared 0.236757 S.D. dependent var 0.002091 S.E. of regression 0.001827 Akaike info criterion -9.753117 Sum squared resid 0.000851 Schwarz criterion -9.684642 Log likelihood 1272.905 Hannan-Quinn criter. -9.725589 F-statistic 21.08534 Durbin-Watson stat 1.793625 Prob(F-statistic) 0.000000
For the max_lag=2 , the program misses out this combination and shows pvalues as only one less than 0.1 , as it should have selected this combination . if you can sort this out
test_program.prg
(1.27 KiB) Downloaded 1229 times
dataprojct.wf1
(1.29 MiB) Downloaded 633 times
and its a small problem to be sorted out for this great achievement
EViews Matt
Re: ERRORHELP
Postby EViews Matt » Sun Dec 09, 2018 7:21 am
That combination of lags isn't one that your program evaluates, so of course the program cannot identify it as the best. Take a close look at your primary estimation line, the line beginning with "equation eq{!i}.ls".
adarshad
Re: ERRORHELP
Postby adarshad » Sun Dec 09, 2018 11:40 am
i am trying but i couldn't understand what are you pointing at.can you make the correction?. as for my primary equation, it uses these combination of lags as y{i} in dependent value is fixed to -1 while else values range from 0 TO -2 ? AND THESE ARE ALL -1; i couldn't understand why its not possible? can you explain whats wrong in my primary line as it should estimate all lags from zero to -lag AND IF ITS WRONG , i guess even all previous estimations were wrong too.my idea was using zero(negative zero is just zero too) to negative two lags ; PLEASE elaborate and leet me whats wrong; your logic was absolute class; a true progammer
equation eq{!i}.ls Y{!i} c X{!i}A(-!lag_a) X{!i}B(-!lag_b) Y{!i}(-1) X{!i}C(-!lag_C)
SHOULD I write primary estimation as above?
EViews Matt
Re: ERRORHELP
Postby EViews Matt » Mon Dec 10, 2018 10:20 am
My point is that the estimates you're evaluating to find the best combination of lags (the "equation eq{!i}.ls" line) and the estimate you're using to record the results for the best combination (the "show eq{!i}.ls" line) do not match. In the former you use the "to" lag range operator, but in the latter you do not, so the results will not be the same. For example, if the best combination of lags was !bestlag_a = 1, !bestlag_b = 1, !bestlag_c = 2, that would have been determined by the estimation:
equation eq{!i}.ls Y{!i} c X{!i}A(0 to -1) X{!i}B(0 to -1) Y{!i}(-1) X{!i}C(0 to -2)
Which is equivalent to:
equation eq{!i}.ls Y{!i} c X{!i}A(0) X{!i}A(-1) X{!i}B(0) X{!i}B(-1) Y{!i}(-1) X{!i}C(0) X{!i}C(-1) X{!i}C(-2)
Buy you'd record the results for:
equation eq{!i}.ls Y{!i} c X{!i}A(-1) X{!i}B(-1) Y{!i}(-1) X{!i}C(-2)
That last estimation is different than the preceding two. Choose whether you want to the lag ranges (0 to ...) or not, and be consistent in the way you perform your estimations.
adarshad
Re: ERRORHELP
Postby adarshad » Wed Dec 19, 2018 11:40 am
sir i have cleared all your suggestions but finally one more thing .
can you help me to modify this code if either it calculates two pvalues jiontly successfully( if there are many options for two significant values, then picks the minimum aic solution) or else it
simply calculates results on the basis of minimum aic for a lagged equation. just two options.
is it possible to do that because it will help me to find consistent results and improved techniques.
just minor changes to this method i guess
can you help me for that
thanks
EViews Matt
Re: ERRORHELP
Postby EViews Matt » Thu Dec 20, 2018 10:34 am
If I understand you correctly, you now want only two cases: 0 or 1 p-values < 0.1, and 2 p-values < 0.1, correct? A small change to the previous !fake_aic calculation can accomplish that.
!fake_aic = eq{!i}.@aic - 1000 * (eq{!i}.@pval(2) < !pval_C and eq{!i}.@pval(3) < !pval_D)
adarshad
Re: ERRORHELP
Postby adarshad » Thu Dec 20, 2018 4:13 pm
I JUST WANT THAT EITHER IT SHOULD SELECT jiontly TWO significant PVALUES LeSS THAN 0.1
or secondly it should select all other on basis of minimum aic irrespective of any pvalue
so either two pvalues less than 0.1 JIONTLY (if more than one pair then selct pair with min aic)
or choose lag having minimum aic; so no preference for one significant pvalue
EViews Matt
Re: ERRORHELP
Postby EViews Matt » Thu Dec 20, 2018 7:05 pm
Okay, that's what my suggested change to !fake_aic should accomplish.
