Page 3 of 5
Re: rename dummy and diagonal dummy
Posted: Thu Apr 06, 2017 10:49 am
by EViews Matt
The first "period" of the series will be NAs, e.g., (NA, NA, NA, 1, 2, 3, 1, 2, 3, ...), because @day(-1) is NA for the first observation. That causes @day<>@day(-1) to evaluate to NA instead of true. NA is interpreted as false, therefore @recode assigns tx(-1) + 1, which is also NA, to the first observation of tx. For the rest of the first period @day<>@day(-1) is false, so @recode continues to assign tx(-1) + 1 to subsequent observations of tx, which just propagates the NA. Only when you hit the second period is @day<>@day(-1) true, and things work correctly from that point onward. The problem is the first evaluation of @day(-1) that evaluates to NA, but you can easily change your @recode condition in many ways to handle that special case. For example,
series tx = @recode(@day<>@day(-1) or @isna(@day(-1)), 1, tx(-1) + 1)
Posted: Thu Apr 06, 2017 1:49 pm
by clubmed
Got it!.
last question: but if i generate a series break trend with this code
series break=@recode(@during("2000m01 2001m05") or @during("2003m10 2004m12") or @during("2006m01 2007m04") or @during("2008m01 2015m02"),1,0)
break=@recode(@during("2005m01 2005m07") or @during("2005m10 2005m12") or @during("2007m01 2007m04") or @during("2008m01 2009m02"),beark(-1)+1,0)
i get "NA" from 2000m01 to 2001m05 in my series, but from 2003m10 2004m12... i get what's i need (break trend) , if i use in the first code @cumsum(1) (normally @cumsum(1) solve this directly) the trend continue (e.g 1 2 3 0 0 4 5 6 0 0 0 0 0 6 7...etc), how can fix this by one way.
Posted: Thu Apr 06, 2017 3:20 pm
by EViews Matt
Odd. There aren't any NAs in the series when I run those two lines (after fixing the typo near the end of the second line, "beark" -> "break").
Posted: Fri Apr 07, 2017 2:16 am
by clubmed
sorry,
if i use this code:
series break=@recode(@during("2000m01 2001m05") or @during("2003m10 2004m12") or @during("2006m01 2007m04") or @during("2008m01 2015m02"),break(-1)+1,0)
from 2000m1 to 2001m05 it start by "NA" from 2000m01 to 2001m05.
how can fix this by one way (i know that i can fix this by Edit)?
Posted: Fri Apr 07, 2017 8:52 am
by EViews Matt
This is the same fundamental problem as your previous series
tx, in this case it's break(-1) evaluating to NA at the first observation. You can fix the issue in much the same way, or for variety:
series break=@recode(@during("2000m01 2001m05") or @during("2003m10 2004m12") or @during("2006m01 2007m04") or @during("2008m01 2015m02"), @nan(break(-1), 0) + 1, 0)
Posted: Fri Apr 07, 2017 10:19 am
by clubmed
I don't know how to thank you, you make a great job, your help is very useful, i wish you great success in the future "EViews Matt". :D
I will thanks "Mr Gareth" too.
Posted: Fri Apr 07, 2017 2:13 pm
by ecofin
Hi everybody,
I would have a follow up question on that: "De-trending with a level shift and/or a broken trend", i have several series that contaned multiple break points, to solve this it is necessary two have two series level shift and broken trend.
1) how can reverse the series d_.... in the previous programs that will be trend ( by one month or by spanning two month... or by week when spanning two weeks or 3 weeks...): e.g. 1 2 3 4 5...
2) same to the first question but trend be T=(1111 2222 3333....) the reason "T" takes this rather odd form is that, when it is multiplied by the seasonal dummies, the resulting trending dummies always sum to zero over each year.
Kind Regards.
Posted: Fri Apr 07, 2017 3:43 pm
by EViews Matt
I'm unsure what you mean by "reverse the series," could you provide a longer example of what you want?
Posted: Sat Apr 08, 2017 2:47 am
by ecofin
All previous programs generate dummy equal 1 and rename it by different way as required "d_{same date}" for each frequency ( day, month, week, interday, or by spanning by two month, two weeks...), how can generate and rename defferent trend "t_{same date}" "b_{same date}" in same time with the series dummy by the previous code (the same logic of previous programs) . below you find an example that what i need.
Posted: Mon Apr 10, 2017 9:00 am
by EViews Matt
I see. You can generate both types of trends with fairly simple @recode statements. For example,
series t_003 = @recode(d_003, @nan(t_003(-1), 0) + 1, 0)
series b_003 = @recode(d_003, 3, 0)
The same idea should work for both the cumulative and non-cumulative dummies (d1_* and d_*).
Posted: Mon Apr 10, 2017 9:30 am
by ecofin
if i use the one of previous code (in page two) it doesn't work correctly, and i would to generate all the (d_, t_, b_, d1_, t1_, b1_) not one by one, and the " series {%series_name1} = @recode({%series_name}, @nan({%series_name}(-1), 0)+2 , 0)" generate this t_001= 1 2 2 00000, here i have just make your code for three spanning by week. have you understood me
!size = 3 'how many weeks per dummy
!first_date_number = @dateval(@otod(1))
for !i = 1 to @obsrange
!week = @datediff(@dateval(@otod(!i)), !first_date_number, "ww")
!id = @floor(!week / !size) + 1
%series_name = "d_" + @str(!id, "i03")
%series_name1 = "t_" + @str(!id, "i03")
%series_name2 = "b_" + @str(!id, "i03")
%series_name3 = "d1_" + @str(!id, "i03")
%series_name4 = "t1_" + @str(!id, "i03")
%series_name5 = "b1_" + @str(!id, "i03")
if not @isobject(%series_name) then
series {%series_name} = @floor(@datediff(@date, !first_date_number, "ww") / !size) + 1 = !id
series {%series_name1} = @recode({%series_name}, @nan({%series_name}(-1), 0)+1, 0)
series {%series_name2} =@recode({%series_name}, 3, 0)
'series {%series_name3}=?
'series {%series_name4}=?
'series {%series_name5}=?
endif
Posted: Mon Apr 10, 2017 10:20 am
by EViews Matt
There are a few bugs. In the line generating series t_*, the series inside the @nan should be %series_name1 not %series_name (note that in my original example it's t_003, not d_003).
series {%series_name1} = @recode({%series_name}, @nan({%series_name1}(-1), 0)+1, 0)
Generating series b_*, the constant 3 needs to be replaced with the unique identifier for the dummy.
series {%series_name2} = @recode({%series_name}, !id, 0)
Generating the basic cumulative dummies, d1_*, is almost exactly he same the non-cumulative dummies, d_*, you just accept any identifier less than or equal to the current identifier ("=" becomes "<=").
series {%series_name3} = @floor(@datediff(@date, !first_date_number, "ww") / !size) + 1 <= !id
Posted: Mon Apr 10, 2017 2:36 pm
by ecofin
Great, thank you for your help EViews Matt.
Nice day.
Posted: Thu Apr 13, 2017 8:00 am
by clubmed
I have make some modification to rename dummy series when i spanning by three weeks or by others frequency with two ways, but the two modification doesn't work:
1/rename dummy by the corresponding start date: d_2000_01_03_001, d_2000_01_24_002, d_2000_02_14_003,...etc (d_{start date}_001), but the series will be renamed by this: d_2000_01_03_001, d_2000_01_10_002, d_2000_02_17_003 with this code:
%series_name = "d_" +@datestr(@dateval(@otod(!id)), "YYYY_MM_DD_")+ @str(!id, "i03")
wfcreate w 03/01/2000 31/12/2001
endif
2/rename dummy by the corresponding start date and end date: d000103_000117_001, d000124_000207_002,...etc (d{start date}_{end date}_001), but the series will be renamed by this d000103_000106_001, d000110_000113_002, ...etc with this code:
%series_name = "d" +@datestr(@dateval(@otod(!id)), "YYMMDD_")+@datestr(@dateval(@otod(!id))+3, "YYMMDD_")+ @str(!id, "i03") but it doesn't work.
how can rename dummy by start date, and by start date and end date, when i spanning by different frequency.
Posted: Thu Apr 13, 2017 9:03 am
by EViews Matt
The solutions to both your questions are the same. At the moment, you're creating your series names by treating !id as an observation and using it in @otod(!id). But !id isn't an observation number, it's a function of the observation numbers that produces a unique value for each group of weeks (every three weeks in your example). More specifically, for the 105 observations in your example, !id ranges from 1 to 35, so @otos(!id) will produce the first 35 dates in your sample. However, you can calculate the observation number of the first week in each group from !id, it's just (!id - 1) * !size + 1. Use that as the argument to @otod. Similar, the observation number of the last week in each group is !id * !size, assuming that produces a valid observation number (since the last group may hold fewer than !size weeks).
