Page 2 of 3
Re: How to specify Maximum Likelihood
Posted: Tue May 19, 2009 11:39 pm
by trubador
It seems you are having a convergence problem now. Your variance specification is too flexible. I am not sure if the scale() coefficient is really necessary. Anyway, you should keep trying different (and plausible) inital values.
Posted: Tue May 19, 2009 11:54 pm
by cuongnh
Dear Trubador, the results are coppied as follows. Please tell me what is the problem? And, I dont understand the initial value for beta (as shown in some example by Eviews):
LogL: UNTITLED
Method: Maximum Likelihood (Marquardt)
Date: 05/20/09 Time: 15:45
Sample: 1 441
Included observations: 441
Evaluation order: By observation
Convergence achieved after 4 iterations
WARNING: Singular covariance - coefficients are not unique
Coefficient Std. Error z-Statistic Prob.
BETA(1) 7.077052 NA NA NA
BETA(2) 0.113217 NA NA NA
BETA(3) -3.909232 NA NA NA
BETA(4) 0.026040 NA NA NA
BETA(5) 0.052618 NA NA NA
BETA(6) 2.781980 NA NA NA
SCALE(1) -0.524479 NA NA NA
ALPHA(1) 1.212937 NA NA NA
Log likelihood -952.1287 Akaike info criterion 4.354325
Avg. log likelihood -2.159022 Schwarz criterion 4.428503
Number of Coefs. 8 Hannan-Quinn criter. 4.383586
Posted: Wed May 20, 2009 12:02 am
by trubador
Could you please post your workfile?
Posted: Wed May 20, 2009 12:09 am
by cuongnh
This file is as the one I 've shown in the last post.
Posted: Wed May 20, 2009 12:16 am
by trubador
As I said before, you do not need the scale() coefficient. Just drop it and try again. You'll see that the model converges properly even if you assign 0 to other coefficients.
Posted: Wed May 20, 2009 12:24 am
by cuongnh
Oh, yes, it is. I would like to calculate DW stats, I tried that with the values in series "res" which I think is the residuals. Is that right? The DW stat I calculated is about 0.83. It is too low. Do you have any idea for this?
Posted: Wed May 20, 2009 12:30 am
by cuongnh
I have just tried to process MLM again from the beginning (in order to be sure all the initial values of beta, alpha are 0). but the interation stopped at "missing... at observation 97". Could you please exolain me more why this happen and in what principles?
Posted: Wed May 20, 2009 12:45 am
by cuongnh
So, it means MLM is not appropriate for solving this low serial correlation in my data. Do you suggest me any method? Might be, check the cointegration relations and using VECM is best. Do you think so?
Posted: Wed May 20, 2009 12:46 am
by trubador
That's because your residuals do have a serial correlation problem, which you can also confirm via correlogram. The problem is that your dependent and independent variables are not stationary. You should really revise your model before going any further.
Each time you run the model, it takes the stored values (from the previous estimation) as starting values. You can fix the values with param command inside logl object.
Posted: Wed May 20, 2009 12:52 am
by trubador
We had this discussion before and tcfoon gave you invaluable insights:
http://forums.eviews.com/viewtopic.php? ... &sk=t&sd=a
At this point, I really do not have much to do and strongly suggest you to spend more time with econometrics textbooks and EViews' user manual.
Posted: Wed May 20, 2009 1:02 am
by cuongnh
Thanks for your introduction of param command. I made it. I highly appreciate that you are with me!
Posted: Fri Jun 12, 2009 1:42 am
by thinhlien
Dear kind Trubador,
Could you pls check your private message or have a quick look at topic 'Program mlogit'.
I would like to receive your help with the explanation of dd2, dd3.
Thanks alot,
thinhlien.
Posted: Sun Apr 22, 2018 9:38 am
by ouerk
Hey
when i estimate the LOGl, i have this error message: log of no positive number .
What can i do to solve this problem ?
thanks
Posted: Sun Apr 22, 2018 9:48 am
Hey
thanks
Don’t take the log of a non positive number.
Posted: Sun Apr 22, 2018 10:32 am
by ouerk
i try with variable with positive value (in all the sample) and the log of this variable is positive too. ( i have indépendant variable y and x and z explicative variable)
i use this command in the logl after created the coefficient beta,scale and alpha:
@logl x z
@logl logl1
res = y - beta(1) - beta(2)*x - beta(3)*z
var = scale(1)*z^alpha(1)
logl1 = log(@dnorm(res/@sqrt(var))) - log(var)/2
when i estimate i have this message error: log of no positive number
when you tell me don t take negatif value , what do you mean?
if i remplace log(var)/2 by (var)/2 (i don t think it was the good transformation to do )==> i don t have message error but i obtain this estimation .How can i do to solve the problem ? thanks
LogL: UNTITLED
Method: Maximum Likelihood (BFGS / Marquardt steps)
Date: 04/22/18 Time: 19:22
Sample: 1 50
Included observations: 50
Evaluation order: By equation
Failure to improve likelihood (non-zero gradients) after 1 iteration
Coefficient covariance computed using outer product of gradients
BETA(1) 0.000000 NA NA NA
BETA(2) 0.000000 NA NA NA
BETA(3) 0.000000 NA NA NA
SCALE(1) 0.000000 NA NA NA
ALPHA(1) 0.000000 NA NA NA
Log likelihood 3224061. Akaike info criterion -128962.2
Avg. log likelihood 64481.22 Schwarz criterion -128962.0
Number of Coefs. 5 Hannan-Quinn criter. -128962.2
