Chow test at all possible break points
Re: Chow test at all possible break points
Dear Gareth, i find the way to get the table with the following command breakls(method=glob,select=high) series01 c series01(-1) [i can't freeze the result in a table when i use this way] or
freeze(tab)eq.multibreak(method=globinfo), using the last one how can i extract the breakdates from the freeze table because the dates are in different rows and in one cell could appear 2 or 5 dates..
is like that
Estimated break dates:
1: 1982M01 -> all in one cell position (25,A)
2: 1965M08, 1991M05 -> also in on cell position (26,A) ...and so on
thank you very much for your help!!!.
is like that
freeze(table)eq.breakls(method=glob) series01 c series01(-1)
@wsplit(@right(table(9,1),44)) ' create svector
it looks like this:
1956M09,
1965M08,
1973M10,
1982M01,
1991M06
is it possible to transform this svector into a date vector??
it looks like this:
1956M09,
1965M08,
1973M10,
1982M01,
1991M06
There is no such thing as a date vector.
Is there any command to fix that value?? or to freeze the vector and ask for its value?? :(
What do you mean by value?
I don't get what you're trying to do with the dates.
You can use the @dateval function to convert the string representation of a date into the EViews internal integer value for that date. But I can't see what you'd do with that integer.
i want to use these value to create dummies and estimate the model with the break date..
so it will be something like that:
scalar Model
if white(!i+1) <0.05 then
Model=1="Model 1: Bootstrap homoskedastic"
else Model=2="Model 2: Bootstrap heteroskedastic"
endif
'!rep=2 'number of replications (bootstrap)
'!n = @obs{%dep}
'!m=@obs{%regs}
'vector(!rep) boot
'for !j=1 to !rep
'{%dep}.resample Yb
'boot(!j)=@var(Yb)
freeze(breakdatetable) eq1.multibreak(method=globinfo) 'to obtain the break dates
@wsplit(@right(table(9,1),44)) 'svector breakdates
if Model=1 then
equation eq1ho{!i,!j}.ls Yb {%regs}
eq1ho.makeresid res1
'series dummy=@recode(@date>@dateval("breakdate"), 1,0) '
'equation eq2ho{!i,!j}.ls Yb {%regs} {%regs}*dummy
'eq2ho.makeresid res2
'Ft(b)= ((!n-!m)*res1-(!n-2*!m)*res2)/res2
'else if Model=2 then
'equation eq1he{!i,!j}.ls Yb {%regs}
'eq1he.makeresid res1
'equation eq2he{!i,!j}.ls Yb {%regs} {%regs}*dummy
'eq2he.makeresid res2
'endif
'endif
'next
'next
scalar Model
endif
'!n = @obs{%dep}
'!m=@obs{%regs}
'vector(!rep) boot
'for !j=1 to !rep
'{%dep}.resample Yb
'boot(!j)=@var(Yb)
if Model=1 then
'endif
'endif
'next
'next
ok, that would work, although you might want to look up the @after and @before functions too.
:) i am trying to store the value in a vector but i get the following error message: An unnamed object cannot be converted to a string in "BREAK=@DATEVAL(@WSPLIT(@RIGHT(TABLE(9,1),44)))"
vector(5) break
freeze(table)eq.breakls(method=glob)series01 c series01(-1)
break=dateval(@wsplit(@right(table(9,1),44)))
what can i do? :(
vector(5) break
what can i do? :(
break=@dateval(@right(table(9,1),44))
the problem with this command is that the vector is being fulfilled with NA :?
Dear Gareth,
I have some problems trying to calculate the Wald statistics, could you please help me
vector Model
Model=1'="Model 1: Bootstrap homoskedastic"
else Model=2'='Model 2: Bootstrap heteroskedastic"
endif
'Bootstrap
!rep=645 'number of replications
vector(!rep) boot
for !j=1 to !rep
{%dep}.resample Yb
boot(!j)=@var(Yb)
table breaks 'to obtain the break dates
freeze(tablebreakls)eq1.breakls(method=glob) series01 c series01(-1)
svector dates= @wsplit(@right(tablebreakls(9,1),44)) 'svector breakdates
for !i=1 to 5
%date = @left(dates(!i),7)
breaks(!i,1)=%date
show breaks
if Model=1 then
'Under the null hypothesis(stability)
equation eq1ho{!i}_{!j}.ls Yb {%regs}
'Under the alternative hypothesis(structural break)
series dummy=@recode(@date>@dateval("breaks"), 1,0) '
equation eq2ho{!i}_{!j}.ls Yb {%regs} {%regs}*dummy
'Bootstrap Wald statistic
Ft(b)= ((eq1ho{!i}_{!j}.@regobs-eq1.@ncoef)*(eq1ho{!i}_{!j}.@se)^2)-(eq2ho{!i}_{!j}.@regobs-2*eq2.@ncoef)*(eq2ho{!i}_{!j}.@se)^2))/(eq2ho{!i}_{!j}.@se)^2)
equation eq1he{!i}_{!j}.ls Yb c series01(-1)
equation eq2he{!i}_{!j}.ls Yb c series01(-1) series01(-1)*dummy
Ft(b)= ((eq1he{!i}_{!j}.@regobs-eq1.@ncoef)*(eq1he{!i}_{!j}.@se)^2)-(eq2he{!i}_{!j}.@regobs-2*eq2.@ncoef)*(eq2he{!i}_{!j}.@se)^2))/(eq2he{!i}_{!j}.@se)^2)
endif
endif
error message: insufficient number of observations in “EQUATION EQ2HE{!I}_{!J}”.LS YB C SERIES01(-1) SERIES01(-1)*DUMMY"
vector Model
endif
'Bootstrap
vector(!rep) boot
for !j=1 to !rep
{%dep}.resample Yb
boot(!j)=@var(Yb)
for !i=1 to 5
breaks(!i,1)=%date
show breaks
if Model=1 then
endif
endif
Sounds like you don't have enough observations to run that regression. You probably have all NAs in the current sample.
Dear Gareth,
You are right the problem is that the dummy is fulfills with NA.. And maybe the reason is that the @dateval(breaks,1,0) give me the date in the following format "YYYYMM" and the @date give me "MM/1/YYYY" how can I change one of them? Is there any possibility to transform the svector to same format to @date or anyway to establish that the @date is express just in year and month without the first day of every month?
Thank you very much for your guidance
for !i=1 to 5
breaks(!i,1)=%date
show breaks
'breaks=@dateval(@str(breaks),"MMDDYYYY") 'trying
'date=@meansby(@date,year,month) 'trying
if Model=1 then
for f!=1 to 5
series dummy=@recode(@date>@date("breaks(!f,1)"), 1,0) '
Ft(b)= ((eq1.@regobs-eq1.@ncoef)*res1-(eq1.@regobs-2*eq1.@ncoef)*res2)/res2
series dummy=@recode(@date>@dateval("breaks(1,1)" , 1,0)
endif
endif
for !i=1 to 5
breaks(!i,1)=%date
show breaks
if Model=1 then
for f!=1 to 5
endif
endif
Change:
to be:
And then a similar change for the other dummy declarations.
%date = breaks(!f,1)
series dummy=@recode(@date>@dateval(%date), 1,0)
thank you very much :) it works!!.
Dear Gareth, with the following commands, the software knows that i want it to calculate the white test of the break date and compare if it is lower than 0.05, in the case it is, it should use model 1 else model 2, after that, it should repeat this procedure on the 4 remaining breaks date. Leaving in the vector "Model" that model used for those 5 breaks?.
for !f=1 to 5
%date=breaks(!f,1)
vector(5,1) Model
if white(@dtoo(%date))<0.05 then Model=1
else Model=2
endif
for !f=1 to 5
%date=breaks(!f,1)
vector(5,1) Model
else Model=2
endif
