return calculation
shineK
Contact:
Re: return calculation
Postby shineK » Tue Jul 03, 2018 10:08 pm
:!: <<URGENT>> :!:
Hi there,
i need to calculate the monthly return by daily data(as attached - RIsna_dwnS_all_cs)
following is the code that i wrote, but the results show lots of NA, please help to check the reason. Thank you so much!!!!!!!!!!
%dir="F:\Thesis\Eviews\St12_Ret_mth\dwnSize\2.RIsna" %dir1="F:\Thesis\Eviews\St12_Ret_mth\csv" output(t,o) {%dir1}\out1 'all data wfopen {%dir}\RIsna_dwnS_all_cs.xlsx range=Sheet1 colhead=0 namepos=all na="#N/A" names=("date") @freq D5 12/31/1969 @smpl @all group o ser* stomna(o, om) rowvector ds1 = @rowextract(om,1) '取dscode scalar alfirm = @columns(om) 'count nobs of firm for !i =1 to 9 series w{!i} = series0{!i} next for !i =10 to @columns(o) series w{!i} = series{!i} next for !i=1 to 9 w{!i}(1)=na '將series第一行變成na next for !i=10 to @columns(o) w{!i}(1)=na next series Mend = @day(+1) =1 for !i = 1 to @columns(o) series riM{!i}= Mend*w{!i} '找出每個月最後一天的RI next group aa riM* for !i =1 to @columns(aa) scalar mcount = 12*(2016-1969) matrix(mcount, 2) m{!i} =na matrix(mcount, 2) ml{!i} =na 'lag !n=0 for !y = 1970 to 2016 for !m=1 to 12 !n=!n+1 smpl if @year=!y and @month=!m m{!i}(!n, 1)=!y*100+!m ml{!i}(!n, 1)=!y*100+!m series riMkk{!i}_!y_!m = na riMkk{!i}_!y_!m = riM{!i} series riMLg{!i}_!y_!m = riM{!i}(-1) stomna(riMkk{!i}_!y_!m, riMk{!i}_!y_!m) stomna(riMLg{!i}_!y_!m, riML{!i}_!y_!m) m{!i}(!n, 2)=@sum(riMk{!i}_!y_!m) if m{!i}(!n, 2) =0 then 'm{!i}(!n, 2) =333 m{!i}(!n, 2) =na endif ml{!i}(!n, 2)=@sum(riML{!i}_!y_!m) if ml{!i}(!n, 2) =0 then 'm{!i}(!n, 2) =333 ml{!i}(!n, 2) =na endif smpl @all next next delete rimk* delete riml* matrix retM{!i}= @ediv(ml{!i}, m{!i})-1 vector c1 = @columnextract(m1, 1) 'monthly date colplace(retM{!i},c1,1) next 'delete w* delete rim* 'combine all retM matrix(mcount, alfirm_act1+1) rrM = na for !i=1 to @columns(aa) vector cc{!i} = @columnextract(retM{!i},2) colplace(rrM,cc{!i}, !i+1) next colplace(rrM,c1,1) rrM.write(t=txt, d=c) F:\Thesis\Eviews\St12_Ret_mth\csv\retM_F_cs.csv
RETM_F_CS.xlsx
result
(1.47 MiB) Downloaded 531 times
(17.38 MiB) Downloaded 553 times
Best,
SK :D
shineK
Contact:
Postby shineK » Tue Jul 03, 2018 10:12 pm
Hi all,
Also,
after calculating the monthly return, i need to calculate the annual return by using monthly return, more important is that the annual period is from July t-1 to Jun t, but i do not know how to select this period out to calculate the annual return, really needs help, thanks a lot!!!!!!!!!
Best,
SK :D
shineK
Contact:
Postby shineK » Tue Jul 03, 2018 11:04 pm
Hi all,
I solved the monthly return problem, thank you.
But still stuck in the yearly part...
Best,
SK :D
