Page 2 of 2
Re: Factor rotation performed on PCA output
Posted: Tue Aug 14, 2012 9:24 am
Your loadings don't appear to be the same (FEVEC). What's the version/date on your copy of EViews?
Posted: Wed Aug 15, 2012 3:13 pm
by bernerth
Just realized there is a page two in this chat chain.
My Eviews version is 7.1, Standard Edition - Sep 10 2010 build
Posted: Wed Aug 15, 2012 3:16 pm
Way out of date. You need to update to the latest version by installing the Upgrade Installer:
http://eviews.com/download/download.html
Posted: Thu Aug 16, 2012 12:05 pm
by bernerth
Thx Glenn, now it worked. Is there a way to perform the varimax rotation on the adjusted factor loadings? By adjusted I mean divide the factor loadings of the principal factors (as derived by the EFA) by the square root of the corresponding eigenvalue? That way I can perform the rotation on the loadings as if they were the loadings of the principal components (as derived by the EFA). I understand that ordinally it won't make a difference, but the actual rotated loadings will be different if I simply perform the rotation on the unadjusted factor loadings.
Thx
T
Posted: Fri Aug 17, 2012 10:46 am
I can't think of an easy way. I think that you *might* be able to compute the covariance matrix and save it using the covariance tools. Then scale it by the eigenvalues in such a way that the factor analysis gives you scaled loadings that match the principal components unscaled loadings. Feed that into the factor analysis routines. But that's just a hunch.
Posted: Fri Aug 17, 2012 11:16 am
by bernerth
Ok thx Glenn. For interpretation purposes the ordinal ordering works for me.
Thx again for all your help.
T
