Stata and Eviews different results
shakyyy87
Re: Stata and Eviews different results
Postby shakyyy87 » Mon Jul 30, 2012 9:14 am
Really , can i please know the values ? and if possible could you attach the work file .
Thank you in advance.
Postby startz » Mon Jul 30, 2012 9:16 am
Null Hypothesis: EXPORTS_OF_GOODS_AND_SER has a unit root
Exogenous: Constant
Lag Length: 0 (Automatic - based on SIC, maxlag=7)
t-Statistic Prob.*
Augmented Dickey-Fuller test statistic -0.657720 0.8429
Test critical values: 1% level -3.661661
5% level -2.960411
10% level -2.619160
*MacKinnon (1996) one-sided p-values.
Augmented Dickey-Fuller Test Equation
Dependent Variable: D(EXPORTS_OF_GOODS_AND_SER)
Method: Least Squares
Date: 07/30/12 Time: 08:24
Sample (adjusted): 2 32
Included observations: 31 after adjustments
EXPORTS_OF_GOODS_AND_SER(-1) -0.027429 0.041703 -0.657720 0.5159
C 7.40E+08 4.71E+08 1.571120 0.1270
R-squared 0.014698 Mean dependent var 4.65E+08
Adjusted R-squared -0.019278 S.D. dependent var 1.20E+09
S.E. of regression 1.21E+09 Akaike info criterion 44.73044
Sum squared resid 4.26E+19 Schwarz criterion 44.82295
Log likelihood -691.3218 Hannan-Quinn criter. 44.76060
F-statistic 0.432596 Durbin-Watson stat 1.986682
Prob(F-statistic) 0.515905
shakyyy87
Postby shakyyy87 » Mon Jul 30, 2012 9:36 am
Great ! that is the result when you do using Eveiws , but the result in stata please ?
Postby startz » Mon Jul 30, 2012 9:39 am
dfuller exports_of_goods_and_ser
Dickey-Fuller test for unit root Number of obs = 31
---------- Interpolated Dickey-Fuller ---------
Test 1% Critical 5% Critical 10% Critical
Statistic Value Value Value
Z(t) -0.658 -3.709 -2.983 -2.623
MacKinnon approximate p-value for Z(t) = 0.8574
. dfuller exports_of_goods_and_ser
shakyyy87
Postby shakyyy87 » Mon Jul 30, 2012 9:46 am
Wow ! unbelievable , i get different answer while using stata. The command for stata is : Dfuller (variable) - this is what you did right ? Also let me know if you have converted the data from string to long and to float in stata 11.1 - Confirm me this please.
Postby startz » Mon Jul 30, 2012 9:49 am
I dropped your Excel file into EVIews and exported the Stata file from EViews. My guess, though I really don't know, is that you made an error in Stata somewhere. It doesn't sound like Stata and EViews disagree.
shakyyy87
Postby shakyyy87 » Mon Jul 30, 2012 10:02 am
Still not sure why my results are different when doing the test in stata alone . Thank you very much for the help. Bless you !
