Page 2 of 2
Re: Rolling: Variance Ratio, Dickey Fuller, Autocorrelation
Posted: Wed Aug 12, 2015 9:21 am
by Ioannis84
I used the above code in order to implement the ADF test on a rolling window of 250 obs. However, regarding the results, in each estimation the sample widens by one observation and is not moved.
In particular, the ADF test is employed for the samples:
1-250, 1-251, 1-252 ....
instead of:
1-250, 2-251, 3-252...
Is there any solution???
Posted: Wed Aug 12, 2015 9:34 am
Hard to say what you've done wrong without seeing what you've done.
Posted: Wed Aug 12, 2015 9:54 am
by Ioannis84
I used the following code:
!width = 250
!lastfirst = @obsrange-!width+1
matrix(!lastfirst, 2) uroot
for !i=1 to !lastfirst
smpl @first+!i-1 @first+!i-1+!width-1
freeze(bb) bond_spread.uroot(const, trend)
uroot(!i, 1) = @val(bb(7, 4))
uroot(!i, 2) = @val(bb(7, 5))
if (@isobject("bb")) then
delete bb
endif
The examined series is bond_spread the overall sample range is 1/1/2008 2/27/2015.
Posted: Wed Aug 12, 2015 9:58 am
And what makes you believe that it is not using a moving window?
Posted: Wed Aug 12, 2015 10:56 am
by Ioannis84
Intending to verify that the code uses a moving window, i created another one workfile and I runned separately the ADF test for the first 3 subsamples (1-250, 2-251, 3-252). Comparing the results, i realized that the code runs the test in the way that i described in my previous message.
Posted: Wed Aug 12, 2015 11:01 am
An easier way to verify it would be with the following:
!width = 250
table mysamples
freeze(bb!i) bond_spread.uroot(const, trend)
uroot(!i, 1) = @val(bb!i(7, 4))
uroot(!i, 2) = @val(bb!i(7, 5))
mysamples(!i,1) = @pagesmpl
show mysamples
The table shows the sample used in each iteration of the loop. I also stopped the deletion of the individual unit root test results, so you can open them up and look at them, and see the sample used.
Posted: Wed Aug 12, 2015 12:21 pm
by Ioannis84
Thank you very much for your help and the prompt reply.
