I used the above code in order to implement the ADF test on a rolling window of 250 obs. However, regarding the results, in each estimation the sample widens by one observation and is not moved.
In particular, the ADF test is employed for the samples:
1-250, 1-251, 1-252 ....
instead of:
1-250, 2-251, 3-252...
Is there any solution???
Rolling: Variance Ratio, Dickey Fuller, Autocorrelation
Re: Rolling: Variance Ratio, Dickey Fuller, Autocorrelation
Hard to say what you've done wrong without seeing what you've done.
I used the following code:
!width = 250
!lastfirst = @obsrange-!width+1
matrix(!lastfirst, 2) uroot
for !i=1 to !lastfirst
smpl @first+!i-1 @first+!i-1+!width-1
freeze(bb) bond_spread.uroot(const, trend)
uroot(!i, 1) = @val(bb(7, 4))
uroot(!i, 2) = @val(bb(7, 5))
if (@isobject("bb")) then
delete bb
endif
The examined series is bond_spread the overall sample range is 1/1/2008 2/27/2015.
!width = 250
delete bb
endif
And what makes you believe that it is not using a moving window?
Intending to verify that the code uses a moving window, i created another one workfile and I runned separately the ADF test for the first 3 subsamples (1-250, 2-251, 3-252). Comparing the results, i realized that the code runs the test in the way that i described in my previous message.
An easier way to verify it would be with the following:
The table shows the sample used in each iteration of the loop. I also stopped the deletion of the individual unit root test results, so you can open them up and look at them, and see the sample used.
!width = 250
table mysamples
freeze(bb!i) bond_spread.uroot(const, trend)
uroot(!i, 1) = @val(bb!i(7, 4))
uroot(!i, 2) = @val(bb!i(7, 5))
mysamples(!i,1) = @pagesmpl
show mysamples
Thank you very much for your help and the prompt reply.
