How to assign labels to observations in a scatter plot?
Re: How to assign labels to observations in a scatter plot?
Postby EViews Gareth » Tue Sep 13, 2011 2:40 pm
Look up the setelem command in the object reference.
Postby EViews Glenn » Wed Sep 14, 2011 9:40 am
If you were to take a look at the setelem entry in the manual, it shows that there is both a
obslabel
and a
dotobslabel
the latter of which has both the obs label and the dot as requested. Replace Gareth's obslabel with the dotobslabel.
Liu
Postby Liu » Wed Sep 14, 2011 1:45 pm
Yes I just read the menu and it's actually in the legend. I didn't realize the meaning of the chart
when I was reading it by myself but now it all came clear to me.
Thanks so much for both of you.
Liu
Postby Liu » Thu Sep 15, 2011 8:55 am
I am trying to use the above finds to do something on my chart.
Now I can have a dot with text next to it. My idea is: suppose I plot a series as a line graph.
What I want is to have text showing the last data point in my graph such as (2001m1, 123.45). My initial solution is to graph a
dot plot of only the last observation (by creating a new series that has only one observation), and then plot a line of the opriginal series
in the same graph.
The problem is: eviews doesn't allow dot to be the type of the first series in a "mixed lines" graph. It can only be area or bar.
Is there a way I can achieve that?
(I attached a photo of what I wish, however this is by placing the cursor next to the observation rather than generate a real text box by command).
Many thanks.
Postby EViews Gareth » Thu Sep 15, 2011 9:02 am
Don't think it can be done.
Postby EViews Glenn » Thu Sep 15, 2011 9:45 am
You can freeze and add the text label manually, but there's nothing automatic.
Liu
Postby Liu » Thu Sep 15, 2011 11:34 am
yes addtext another way I was thinking. and that leads to another thing.
as you know, graph.addtext(x,y,textcolor) is the command to locate the text box coordinates.
I just wonder if there is a way to let the program to return the coordinates of a certain data point?
for example, for an observation of (123.45,2001q1), is there a way to return the coordinate of this datapoint from the
graph?
Postby EViews Gareth » Thu Sep 15, 2011 11:37 am
No, which is why it impossible to add the text automatically.
CharlieEVIEWS
Postby CharlieEVIEWS » Tue Jan 20, 2015 5:17 pm
Dear all,
I'm struggling to find the command line/batch syntax to change the font on .setobslabel. For example, taking a minor variation on Gareths example from above (with no alpha series), how would I change the size of the 'h' in the graph here without using the menus?
create u 20 series x=nrnd series y=nrnd group g x y freeze(graph1) g.scatpair graph1.setelem(1) symbol(obslabel) graph1.setobslabel(series) h h h h h h h h h h h h h h h h h h h h h h h h show graph1
Best wishes as always
Charlie
Postby EViews Jason » Wed Jan 21, 2015 9:15 am
It depends on which h you wish to set the font for.
If you want to change the font for the labels on the axes use
graph1.setfont axes(20) 'set to 20pt
If you want to change the font for the labels within the graph
graph1.setfont obs(16) 'set to 16pt
