Page 2 of 2
Re: stacked bar plus line graph
Posted: Thu Aug 18, 2016 8:34 am
by osindi
sorry how do you freeze it (using code) so that it's a graph object, but still stackedbars + line?
Thanks,
Posted: Thu Aug 18, 2016 9:04 am
How are you making it (via code) with the group?
Posted: Thu Aug 18, 2016 9:06 am
by osindi
I used the code: group1.mixed stackedbar(1,2,3,4,5,6) line(7)
freeze(mygraph) group1.mixed stackedbar(1,2,3,4,5,6) line(7)
Posted: Wed Feb 23, 2022 3:34 pm
by alexanderk
Hi, this chart type does not seem to work, when I have both negative and positive contributions in the group. The positive contributions should start from the zero horizontal axis going upwards and at the same time the negative contributions should start from the zero horizontal axis, but going in the downwards direction. But this does not seem to be the case. When I have both positive and negative ones in one period, they just stack up incorrectly, not starting from zero.
Is there a solution to this?
Many thanks.
Alexander
Posted: Wed Feb 23, 2022 5:29 pm
- 2022-02-23_162910.png (43.69 KiB) Viewed 67782 times
Posted: Thu Feb 24, 2022 2:58 am
by alexanderk
Thank you, this is very useful.
Posted: Wed May 28, 2025 10:32 am
by CecileBF
and how do you code symbol (FILLEDCIRCLE) instead of a line?
Posted: Wed May 28, 2025 5:35 pm
In what sort of graph?
Posted: Fri May 30, 2025 2:31 am
by CecileBF
exactly these types of graphs: stackedbars (representing the contibutions) + symbol "circle" instead of a line (for the total).
Posted: Fri May 30, 2025 7:45 am
wfcreate u 20
series x=@rnd
series y=@rnd
series z=@rnd
group g x y z
freeze(gr) g.mixed stackedbar(1,2) line(3)
gr.setelem(1) symbol(filledcircle) linepattern(none)
show gr
Posted: Mon Jun 16, 2025 2:27 am
by CecileBF
This works well, thank you!
