stacked bar plus line graph
osindi
Re: stacked bar plus line graph
Postby osindi » Thu Aug 18, 2016 8:34 am
sorry how do you freeze it (using code) so that it's a graph object, but still stackedbars + line?
Thanks,
Postby EViews Gareth » Thu Aug 18, 2016 9:04 am
How are you making it (via code) with the group?
osindi
Postby osindi » Thu Aug 18, 2016 9:06 am
I used the code: group1.mixed stackedbar(1,2,3,4,5,6) line(7)
Postby EViews Gareth » Thu Aug 18, 2016 9:06 am
freeze(mygraph) group1.mixed stackedbar(1,2,3,4,5,6) line(7)
alexanderk
Postby alexanderk » Wed Feb 23, 2022 3:34 pm
Hi, this chart type does not seem to work, when I have both negative and positive contributions in the group. The positive contributions should start from the zero horizontal axis going upwards and at the same time the negative contributions should start from the zero horizontal axis, but going in the downwards direction. But this does not seem to be the case. When I have both positive and negative ones in one period, they just stack up incorrectly, not starting from zero.
Is there a solution to this?
Many thanks.
Alexander
Postby EViews Gareth » Wed Feb 23, 2022 5:29 pm
alexanderk
Postby alexanderk » Thu Feb 24, 2022 2:58 am
Thank you, this is very useful.
CecileBF
Postby CecileBF » Wed May 28, 2025 10:32 am
and how do you code symbol (FILLEDCIRCLE) instead of a line?
Postby EViews Gareth » Wed May 28, 2025 5:35 pm
In what sort of graph?
CecileBF
Postby CecileBF » Fri May 30, 2025 2:31 am
exactly these types of graphs: stackedbars (representing the contibutions) + symbol "circle" instead of a line (for the total).
Postby EViews Gareth » Fri May 30, 2025 7:45 am
wfcreate u 20 series x=@rnd series y=@rnd series z=@rnd group g x y z freeze(gr) g.mixed stackedbar(1,2) line(3) gr.setelem(1) symbol(filledcircle) linepattern(none) show gr
CecileBF
Postby CecileBF » Mon Jun 16, 2025 2:27 am
This works well, thank you!
