Page 2 of 2
Re: Dummy Variable Help
Posted: Sat May 01, 2010 9:38 am
by Becca88222
YAY! Thanks!!!
Okay my final question is:
For dummy variables can I only use the numbers 0 and 1 or can I have 4 different education levels (college, advanced, high, junior) and number them 0,1,2,3 respectively?
Posted: Sat May 01, 2010 9:45 am
by startz
0 and 1 only.
Posted: Sat May 08, 2010 7:31 am
by Dataminer
Becca88222
You can certainly do this as far as OLS is concerned. The issue is its interpretation. Implicitly you are saying that the effect of this education variable on the depvar. is the same difference between cases with values 0 and 1 ('college' an 'advanced') as it is is between 2 and 3 ('high' and 'junior').This is seldom credible!
More typically one creates a dummy variable for each of the mutually exclusive and exhaustive categories (here 4?). For each case these dummies will either take value 1 if the category applies or 0 if it doesn't. Then you can either put all dummmies into the estimating equation and no constant so that the coefficient estimates indicate the effect of each category on the depvar. Also putting the intercept into the model here creates the 'dummy variable trap' (see any econometrics text) i.e. perfect multicolinearity. Alternatively use the intercept and dummies but leave one dummy out. The intercept measures the effect of the omitted category and the other dummy coefs measure the marginal effect of each category over the omitted one. Both methods produce identical (interpretative) results for a common dataset.
