Page 2 of 2
Re: LOOP PROGRAMMING
Posted: Tue Oct 23, 2018 11:03 am
by EViews Matt
I merely opened your workfile, created a new program, pasted in your code (with the required "next"):
for !i = 1 to 28
equation eq!i.ls y!i x!ia x!ib x!ic x!id c
Clicked the "Run" button, and the equations were created successfully.
Posted: Tue Oct 23, 2018 2:39 pm
by adarshad
i have tried my code based on your guidance but all the times it doesnot work;i am using eviews8 and i run code in command window but it comes with error.i have my datafile sent to you.i open it and run this code in window but it comes with error;;;as i mentioned;please help me;;i am very near to my finding after long work
Posted: Tue Oct 23, 2018 2:40 pm
by adarshad
what do you mean by created a new program
Posted: Tue Oct 23, 2018 2:44 pm
by adarshad
you mean the upper white space;;you cannot understand the anxiety i feeling
Posted: Tue Oct 23, 2018 2:54 pm
by adarshad
thankyou i got how to run the program ;i wasnot running program in program window and was doing in command window;now i can do it in program window and run and extend my analysis.thankyou for the guidance and persistent help;i was just doomed by my ignorance;now atleast i can try doing my work thanks
Posted: Tue Oct 23, 2018 4:10 pm
The best way to cure your ignorance is to read the documentation and links that people have given you in this thread. There are no short cuts.
Posted: Thu Oct 25, 2018 3:18 am
by adarshad
'create matrix to store pvalues. We'll be running 28 regressions with SIX pvalues in each row , five for five independent variables and one for intercept
matrix(6,28) pv
matrix(6,28) coefs 'create matrix to store coefficients
vector(28) r2s 'create vector to store rsquare value
vector(28) aic 'create vector to store akaike information criteria value
'create empty equation to be used inside the loop
equation eq
!rowcounter=1
'run pairwise regressions between Yi and Xi
for !i=1 to 28
'estimate equation
eq.ls y{!i} c x{!i}A(-1) x{!i}B x{!i}C x{!i}D x{!i}E
'store coefficients into matrix
colplace(pv, eq.@pval, !i)
colplace(coefs, eq.@coefs, !i)
r2s(!rowcounter) = eq.@r2
aic(!rowcounter) = eq.@aic
!rowcounter = !rowcounter+1
Posted: Thu Oct 25, 2018 3:20 am
by adarshad
can you help me to define the program to select best value of lg for all regressors in all equations to find best probable model or atleast for each equation seperaely but for all regressors seperately;;any guideline;;thanks for your help
Posted: Thu Oct 25, 2018 9:10 am
by adarshad
i require help fo aic selection for one regressor or may be multiple regressors and multiple equations.can someone do that
Posted: Thu Oct 25, 2018 9:22 am
adarshad,
It is unlikely that someone is going to write programs for you. If you are going to be doing a lot of this, you probably need to figure out how to do this for yourself. People may be able to help find a specific bug or give you suggestions, but the work is going to mostly have to be your own.
Posted: Thu Oct 25, 2018 9:50 am
by adarshad
and can i jion differrent vctor and matrixs having same number of rows into one matrix to get output in one matrix
Posted: Thu Oct 25, 2018 9:52 am
by adarshad
can you give any link for calculating aic for multiple regerrsos;
i had worked my way up and its lot of learning but i have not seen any program selecting lag value for multiple regressors
Posted: Thu Oct 25, 2018 9:54 am
EViews automatically computes and displays the AIC for you every time you run a regression.
Posted: Thu Oct 25, 2018 10:33 am
by adarshad
i just want to calculate best lag value on the basis of aic for multiple regressors
