MTOS
Re: MTOS
Postby EViews Steve » Thu Oct 04, 2018 6:40 am
Try creating a separate %path string value first:
mtos(r1, g1, s1) if @isobject("s1") then delete s1 endif %path = "C:\Users\Dhitya\Desktop\test\" + %file wfsave(type=excelxml) %path @keep date return g1
dhityayl
Re: MTOS
Postby dhityayl » Thu Oct 04, 2018 6:49 am
Hi Steve, I've tried that, but the file saved to my folder is not in excel but in csv file and i don't think that the file saved is the right series. is there anything else wrong with my code? I attached the csv file saved to my folder in this post.
Thankyou
cd "c:\Users\Dhitya\Desktop\Program\dataset" %filenames = @wdir("c:\Users\Dhitya\Desktop\Program\dataset") for !k=1 to @wcount(%filenames) %file = @word(%filenames, !k) wfopen %file import c:\Users\Dhitya\Desktop\Program\dataset\index\Indeks_2002.csv import c:\Users\Dhitya\Desktop\Program\dataset\index\FF3_2002.csv genr return=(((close-close(-1))/close(-1))*100)-rf !window = 60 !step = 1 !length = @obsrange equation eq1 !nrolls = @round((!length-!window+1)/!step) matrix(5,!nrolls) coefmat!k !j=0 for !i = 1 to !length-!window+1-!step step !step !j=!j+1 smpl @first+!i-1 @first+!i+!window-2 equation eq1.ls return c indeks mkt_rf smb hml colplace(coefmat!k, eq1.@coefs,!j) matrix(!nrolls,5) r1 matrix r1=@transpose (coefmat!k) series rbc series rbindeks series rbmkt series rbsmb series rbhml group g1 rbc rbindeks rbmkt rbsmb rbhml sample s1 @first+59 @last mtos(r1, g1, s1) if @isobject("s1") then delete s1 endif %path = "C:\Users\Dhitya\Desktop\test\" + %file wfsave(type=excelxml) %path @keep date return g1 'close @all next next
1301.T.csv
(23.47 KiB) Downloaded 455 times
Re: MTOS
Postby EViews Steve » Thu Oct 04, 2018 6:54 am
if %filename was originally a name with a .csv file extension, then the resulting new excel file will also have that name since you told EViews to use that name. The file is still an excelxml file format, but the extension is just wrong.
If you rename the file to have an xlsx file extension, then you'll be able to open it in excel just fine.
Try this bit of code next:
%path = "C:\Users\Dhitya\Desktop\test\" + %file + ".xlsx" wfsave(type=excelxml) %path @keep date return g1
dhityayl
Re: MTOS
Postby dhityayl » Thu Oct 04, 2018 6:58 am
Hi Steve,
The code works well for me.
Thank you so much for the help.
