Page 2 of 8
Re: An introduction to EViews programming.
Posted: Tue Aug 31, 2010 2:32 pm
by eviews_user_2010
I like to modify the code below (it's one of the sample programs) to include the names of the depedent and independent variables of the regressions and to store these names in the vector/matrix output. For example, the first regression would be EQ_GDP_UNEMP. I would appreciate any help. Thanks. Dan
'create a workfile
wfcreate q 1990 2010
'create a group which will contain the xs
group xs
'create 5 series
for %i GDP UNEMP INFL CPI M1
series {%i}=nrnd
xs.add {%i}
'create vector to store r-squares
vector(10) r2s
'create empty equation to be used inside the loop
equation eq
''counter of how many equations we have run
!rowcounter=1
'run pairwise regressions between each series
for !i=1 to xs.@count-1
%iname = xs.@seriesname(!i)
for !j=!i+1 to xs.@count
%jname = xs.@seriesname(!j)
eq.ls {%iname} c {%jname}
r2s(!rowcounter) = eq.@r2
!rowcounter = !rowcounter+1
Posted: Tue Aug 31, 2010 2:45 pm
'create a workfile wfcreate q 1990 2010 'create a group which will contain the xs group xs 'create 5 series for %i GDP UNEMP INFL CPI M1 series {%i}=nrnd xs.add {%i} next 'create vector to store r-squares vector(10) r2s 'create empty equation to be used inside the loop equation eq ''counter of how many equations we have run !rowcounter=1 table equation_vars 'run pairwise regressions between each series for !i=1 to xs.@count-1 %iname = xs.@seriesname(!i) for !j=!i+1 to xs.@count %jname = xs.@seriesname(!j) eq.ls {%iname} c {%jname} r2s(!rowcounter) = eq.@r2 equation_vars(!i,1) = %iname equation_vars(!i,2) = %jname !rowcounter = !rowcounter+1 next next
something along those lines.
Posted: Wed Sep 22, 2010 8:29 am
by eviews_user_2010
Thanks E-view Gareth for your suggestion.
I've implemented a modified version of your suggestion into my code (please see below). This code, based on one of your examples, is to run regressions with every single possible combination of the independent variables using the same dependent variable, which is a lot like a piecewise linear regression, but this code will generate a table of all the possible combinations.
Currently, I'm trying to improve the code so that it would capture the t-statistics for the independent variables, including the constant. From perusing this website and other posts, it seems that I need to use @coef, but I'm not sure the exact syntax for t-statitiscs.
One other feature of interest is to be able to generate the foor loop automatically. I might have over 100 possible independent variables, which means with this program I would need 100 loops. It would be a nice feature if it could automatically generate the additional foor loops.
Thanks a lot,
series GDP = nrnd
group xs
for %i UNEMP INFL CPI
series {%i} = nrnd
xs.add {%i}
vector(25) r2s
equation eq
!rowcounter=1
table equation_vars
eq.ls d(GDP) c d({%iname})
r2s (!rowcounter) = eq.@r2
equation_vars(!rowcounter) = "GDP"
equation_vars(!rowcounter, !i+1) = %iname
eq.ls d(GDP) c d({%iname}) d({%jname})
equation_vars(!rowcounter, !j+1) = %jname
for !k= !j+1 to xs.@count
%kname = xs.@seriesname(!k)
eq.ls d(GDP) c d({%iname}) d({%jname}) d({%kname})
equation_vars(!rowcounter, !k+1) = %kname
Posted: Wed Sep 22, 2010 9:49 am
You can use @tstats to obtain the t-statistics from an equation.
Something similar to this:
http://forums.eviews.com/viewtopic.php?f=15&t=878
but rather than using @coefs to store the coefficients, use @tstats to store the t-statistics.
Posted: Wed Sep 22, 2010 11:41 am
by eviews_user_2010
Thanks a lot Eviews_Garenth. I was just about to post a message that I found out that I could capture the tstats using @tstat.
Do you happen to know how to create an automatic additional loop to account for additional independent variables in the group as shown in below code? The number of loops in this code depends on the number of variables in the xs group. Is there a way to create a program to automatically generate a loop for each independent variable?
series GDP = nrnd
group xs
series {%i} = nrnd
xs.add {%i}
vector(7) r2s
table equation_vars
table tstats
equation eq
!rowcounter=1
!columncounter =1
tstats(!rowcounter) = "N/A"
tstats(!rowcounter, !columncounter+1) = eq.@tstat(!columncounter)
tstats(!rowcounter, !columncounter+2) = eq.@tstat(!columncounter+1)
equation_vars(!rowcounter, !columncounter+1) = "C"
equation_vars(!rowcounter, !columncounter+2) = %iname
tstats(!rowcounter, !columncounter+3) = eq.@tstat(!columncounter+2)
equation_vars(!rowcounter, !columncounter+3) = %jname
tstats(!rowcounter, !columncounter+4) = eq.@tstat(!columncounter+3)
equation_vars(!rowcounter, !columncounter+4) = %kname
Posted: Wed Sep 22, 2010 11:47 am
I don't understand the question. Perhaps you could make a smaller, easier example if what you're trying to do.
Posted: Thu Jan 13, 2011 1:19 pm
by puf
want to estimate GARCH(1,1) model for the variable retx (stock return). I found that I can do it using command
equation eq.ARCH(1,1) retx
Similarly, I can get the coefficients using commands
scalar omega = eq.c(1)
scalar alpha = eq.c(2)
scalar beta = eq.c(3)
However, I have no idea how to get p-values of these coefficients. Is there a general rule how to get different estimetes (e.g. coefficients, their p-values, Rsquared, AIC,...) from an estimated equation? If yes, please tell me about it, if not, is there a list of variables which can be obtained from an estimated equation?
thank you
Posted: Thu Jan 13, 2011 1:51 pm
Look at the start of the equation section of the object reference. It lists all equation data members.
Posted: Wed Jul 20, 2011 10:46 am
by roteirofigo
How can I store the coefficients with the highest R-squares?
Posted: Wed Jul 20, 2011 10:50 am
A coefficient doesn't have an R-squared, so I'm not sure I understand the question.
Posted: Thu Aug 11, 2011 7:43 am
by Hottax
I really a beginner in EViews program..please help me how to create different series below (by using EViews7)
1. Create a series X1 whose element satisfy
- the number of elements is 100
- all alements are zero
2. Create a series X2 of size 100 with the first element is being 1, the second is 2, the third is 3,...,the last is 100
3. Create a series X3 of size 100 with the first element is being 2, the second is 4, the third is 6,...,the last is 200
4. Create a series X4 with each element being the logarithm value of the corresponding element of X1. and how to graph series X1 against and X4
(X1 Horizontal axis and X4 Vertical axis)..
is it different with EViews 6 or not?
thank you very much.
Posted: Thu Aug 11, 2011 7:52 am
by startz
You might want to start by reading the free chapters of EViews Illustrated posted at http://www.eviews.com/illustrated/illustrated.html.
Posted: Thu Aug 11, 2011 8:30 am
by Hottax
Thank you for your quick reply..I understand now how to solve and create series X1-X3...and about series X4, is it ok if I just put it this way series X4 = log series x1
thank you..
Posted: Thu Aug 11, 2011 8:57 am
by startz
Just series x4 = log(x1)
Posted: Fri Aug 12, 2011 1:42 am
by Hottax
Please help me again, how to draw a graph with the function : f(x) = x^3 + 2x^2 - x + 4
Can I draw the graph directly by using EViews program (6 or 7 version)..or firstly I compute in Excel and then copy it to EViews?
Thanks a lot..
