Page 2 of 3
Re: Switch Regression Model Problem
Posted: Thu Aug 06, 2015 9:00 pm
Well I guess you have to ask yourself why you disabled automatic updates :D
At this point, given the mess you're in, you're probably best just uninstalling and re-installing with the latest installer.
http://www.eviews.com/download/ev8downlinks.html
Posted: Thu Aug 27, 2015 10:50 pm
by nicotrader
I finally solved the problem.
Unfortunately it has presented a new problem:
pretty much when i go to select the sample es. 1 5000, just end and the output is displayed is known that the model was estimated over the whole sample and not just on the range
1 5000! Why??? In switch regression it is not possible to select a different sample from whole series loaded?
Posted: Thu Aug 27, 2015 10:54 pm
Switching regression allows samples in the same way as every other type of estimation in EViews.
Posted: Thu Aug 27, 2015 11:51 pm
by nicotrader
Ok so why not let me select a sample?
Posted: Fri Aug 28, 2015 12:07 am
by nicotrader
the full data set is of 54993 observations. I selected a sample 1 5000 but the output returns the entire range. Why!?
Posted: Fri Aug 28, 2015 6:28 am
Perhaps you could post the exact commands, showing how you selected the sample. Also, check the sample specification in the equation estimation dialog.
Posted: Fri Aug 28, 2015 6:50 am
There is nothing in that screenshot that indicates you used a sample of "1 5000"
Posted: Fri Aug 28, 2015 11:54 am
by nicotrader
Posted: Fri Aug 28, 2015 12:26 pm
Posted: Fri Aug 28, 2015 12:34 pm
by nicotrader
Now it works is probably a bug. Sometimes it works sometimes not, changing the series.
But I have another question:
if i value on a sample of 5000 when i go to estimate the model the odds are up to 5000. At this point if i do forecasting, however, it does not allow me to extend the odds in any standard but only the result of regression. How can I do?
Posted: Sun Sep 06, 2015 9:48 pm
by nicotrader
Any advice??
Posted: Sun Sep 06, 2015 10:45 pm
Could you rephrase your question so that it is understandable?
Posted: Wed Sep 09, 2015 9:49 am
by nicotrader
Why the probability of an estimate Markov switches are not testable out of sample but only in sample?
What good has test only in sample?
Posted: Wed Sep 09, 2015 10:43 am
It isn't clear exactly what you want to do. What do you want to compare out-of-sample estimated Markov switches to?
Posted: Thu Sep 10, 2015 12:43 am
by nicotrader
I would like to test in sample and out of sample the state probabilities
