Page 8 of 9
Re: DCCGARCH11
Posted: Mon Jan 09, 2017 12:58 am
by miska
Hello Trubador, could you please post a link to document (dcc model add in) again, I am not able to download it via existing link posted in forum. Thank you.
Re: DCCGARCH11
Posted: Sun Jan 15, 2017 8:49 am
by miska
I am using Eviews 9 and I keep getting this result "Optimization failed: unable to evaluate objective at optimization starting values." and my rhos are all "NA."
Could you please help?
Dear Trubador, I have the same problem. Could you please advise if the problem is with Eviews 9 amd add in compatibility or with our data settings.
Thank you
Re: DCCGARCH11
Posted: Fri Jul 07, 2017 5:38 pm
by pdwhoward
The latest Eviews 10 patch broke the functionality of this toolbox. When I try to run an estimation, now Eviews crashes. Does anyone else have this issue?
Re: DCCGARCH11
Posted: Tue Jul 11, 2017 10:27 am
by EViews Glenn
Could you provide data and clear instructions on how to replicate. That would help a great deal. Thanks.
Re: DCCGARCH11
Posted: Sat Aug 05, 2017 11:41 pm
by izunna
I'm experiencing problem with DCCGARCH(1,1) add-in. I have install the DCCGARCH add-in to the add-in manager. However, any time I run the DCC(1,1) test, Eviews stops working. I'm using Eviews 9. Please does anyone have an idea of what I should do to get it running.
Re: DCCGARCH11
Posted: Mon Aug 07, 2017 1:32 am
by divac
Any chance you are running AR(1) model for the mean or using any other regressors?
Re: DCCGARCH11
Posted: Mon Aug 07, 2017 1:52 am
by divac
I have a different problem with the add-in. I am trying to run a program with a large number of loops in Eviews 9.5. I've noticed that after 15 minutes of running a program file in the quiet mode Eviews shows an error message. One message was saying something like "!TODAY is not defined" and the second one was "%TYPE is invalid"...
It works fine for say 5-10 stocks (I started with 3 stocks and then increased it to 5 and then 10; all is estimated fine). So, I thought the loop works. However, once I increased the code to 50 stocks both runs it stopped on the correlation 307 or 308 or in about 15 minutes. It also works if I restart the loop from say a pair combination number 290. It just go through the 307th or 308th pair of stocks just fine until it breaks again in 15 minutes time or on the next 600th correlation or so.
Now I've tried it on my home PC. I've got "!TODAY is not defined" message on stocks pair number 126, after around 6 minutes. Can it be because I am using EViews via Jukebox, an app that my Uni supplies so everyone has a remote access to all programs purchased by the Uni? Also I have a Mac at home and I am using Parallels Desktop for Windows, while at Uni it is Windows 10 PC.
Can I somehow fix this? What happens if I increase the tolerance for errors? Now the program stops if one error comes up. Here is the code I am using (the data attached):
'create empty equation to be used inside the loop
equation eq
'counter of how many equations we have run
!rowcounter=1
'step 1 (as if it is a 3-step procedure)
for !i=1 to 50
!rowcounter = !i
for !j=1 to 50
if !i<>!j then
equation eq{!i}.ls x{!i} c ar(1)
eq{!i}.makeresid x{!i}r
endif
'company 1
for !i=2 to 50
!rowcounter = !i
' for !j=2 to 50
if !i<>!j then
group g1{!i} x1r x{!i}r
g1{!i}.dccgarch11(unifit="GARCH",ctarget,correl,dccout,unigarch)
endif
'next
'company 2
for !i=3 to 50
!rowcounter = !i
' for !j=3 to 50
if !i<>!j then
group g2{!i} x2r x{!i}r
g2{!i}.dccgarch11(unifit="GARCH",ctarget,correl,dccout,unigarch)
endif
'next
'company 3
for !i=4 to 50
!rowcounter = !i
' for !j=4 to 50
if !i<>!j then
group g3{!i} x3r x{!i}r
g3{!i}.dccgarch11(unifit="GARCH",ctarget,correl,dccout,unigarch)
endif
'next
'company 4
for !i=5 to 50
!rowcounter = !i
' for !j=5 to 50
if !i<>!j then
group g4{!i} x4r x{!i}r
g4{!i}.dccgarch11(unifit="GARCH",ctarget,correl,dccout,unigarch)
endif
Re: DCCGARCH11
Posted: Mon Aug 07, 2017 3:49 am
by izunna
Yes, I'm running an AR(1) with a regressor in the mean equation and a regressor in the variance equation. Please, what should I do?
Re: DCCGARCH11
Posted: Mon Aug 07, 2017 4:26 am
by izunna
I have attached the screen shot of the test and what happens when I click on Ok.
Re: DCCGARCH11
Posted: Mon Aug 07, 2017 7:05 am
by divac
Ok, this is what has been discussed on here. The way I understood it is that you need to run your AR(1) model with other regressors before you use the add-in. You then use the residuals in the DCCGARCH11 add-in.
Re: DCCGARCH11
Posted: Mon Aug 07, 2017 7:56 am
by izunna
Thanks for the information. I will try it and then get back to you asap
Re: DCCGARCH11
Posted: Tue Aug 08, 2017 7:54 pm
by izunna
Please, I have tried to run the test following the suggestion you gave to me but I still experienced the same problem. I'm to quite sure if I was doing it the right way though. What I did was to run an AR(1) model for the each of the two variables and save their residuals. In the DCCGARCH(1,1) specification window, I entered the residuals as the return series and the number of lags in the mean equation I entered 1. Every other thing in the specification window is set as a default setting. Please any further clue as to what I should do. Thanks
Re: DCCGARCH11
Posted: Thu Aug 10, 2017 2:44 am
by izunna
I'm experiencing some problems using add-in for DCCGARCH(1,1) in Eviews 9. The problem is whenever I run the DCCGARCH(1,1), the eviews stops working. Someone on this platform suggested that I should run the AR model separately and provide the residuals as inputs for the return series in the DCC add-in. I have done that but the problem still persist. Please if there is anyone who have encountered this type of problem before and Knows exactly what I should do, kindly assist me. You also contact me via my email at
anyikwaizunna2000@yahoo.com.
Re: DCCGARCH11
Posted: Thu Apr 26, 2018 7:08 pm
by arinjanita
Hi, I'm currently experiencing some error in estimating MGARCH-DCC. I'm following the code I obtained from this forum but somehow I got the notification of Missing Value of the LogL. Perhaps anyone can shed some lights on this problem. Another one is, I have downloaded the DCC Add-In for EViews 9 but have no idea how to begin with this add in. Your reply and guidance are greatly appreciated.
Re: DCCGARCH11
Posted: Sun Apr 07, 2019 1:51 pm
by theocharis_iosifidis
Dear trubador. First and foremost, thank you very much for the very effective add-in that you presented in the forum. It has facilitated many researches since it incorporates DCC-GARCH in eviews which is an innovation. However, if you have some free time i would like you to clarify something regarding the correct application of its procedure. I am currently conducting a research over the dynamic correlation between oil price shocks and the stock markets in oil importing and oil exporting countries. I have all of the necessary data downloaded and I have removed the N/A values. My question is what exactly to include in the empty boxes of the estimation process. In the first one which refers to the return series i am considering to put the returns of the oil index and the returns of one of the stock markets. Is it correct or should i include only one of them?
Moreover, on the boxes of exogenous variables in the mean and variance equation I am considering to put the constant term and my exogenous variable. Is this correct? Or should I include something else?
Again, Thank you very much for the valuable feedback that you offered !!!!
