Basic Rolling Regression
Charles_gre
Re: Basic Rolling Regression
Postby Charles_gre » Mon Apr 03, 2017 7:09 am
Thank you for your help. I used the roll add-in and I managed to get the desired output.
I do not know if you can help me please.
I am trying to extract the s.e of the regression from a number of rolling regressions. I have looked at the commands and programs in the help manual. However, I did not manage the code to extract the s.e of the rolling regression like the one shown hereunder:
myroll.extractresidstat(stat=r2s) roll_r2
I am understanding that the above code extracts the R-squared of the residuals of a rolling regression. In my case, I want the s.e of the regression and not the R-squared, what shall I write instead of r2s? I do have a lot of rolling regressions, therefore knowing this would make the process a lot easier.
As indicated in my previous post this is urgent as I need this for my thesis. I appreciate all the help which you give me.
Postby EViews Gareth » Mon Apr 03, 2017 8:43 am
The add-in doesn't support saving the ses. But it should be straight forward for you to edit the add-in code to do it.
Charles_gre
Postby Charles_gre » Mon Apr 03, 2017 9:45 am
Dear Gareth, Thank you for your answer, please note that I am a beginner here and I do not know how to do this.
How am I going to produce a code so that Eviews can extract the s.e of the regression? I am assuming that it is similar to this one:
logmode +addins
include .\globals.prg
%name = "roll_r2"
%stat = ""
!result = 1
call r2diag(!result, %name,%stat)
if !result = -1 then
stop
endif
call r2extract(%name, %stat)
which is the code for the r2.
Postby EViews Gareth » Mon Apr 03, 2017 2:14 pm
Just look at the current rolling regression program and change the bit that stores the r-squared (equation.@r2) to store the standard error instead (equation.@se)
umut
Postby umut » Mon Apr 10, 2017 8:00 am
Thank you very much for this topic. It helped a lot to me as a beginner in programming. I am benefited a lot from Esther's and Gareth's codes. However, I still couldn't reach the result.
I try to do univariate electricity price forecast the following 24 hours (24-step-ahead dynamic forecast) by using the previous 2 year's hourly data (17520 observations). I changed the Esther's code, but I can only get the forecast for the 24th hours, not for the hours 1-23. I want to do these 24-step ahead forecasts in a rolling window scheme for all days of the third year by using the actual values. I share the changed version of the program below. If you could help me, I will be very grateful.
'run rolling regression
' set window size
!window = 17520
' set step size
!step = 24
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq01
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'matrix to store coefficient estimates
matrix(3,!nrolls) coefmat ' where 3 is the number of coefficients
'series to store forecast estimates
series fcast
'*EDITED: catching start and end points
%start = "@first" '@otod(@ifirst(ser))
%end = "@last" '@otod(@ilast(ser))
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
for !i = 1 to !length-!window+1-!step step !step
!j=!j+1
' set sample for estimation period
%first = @otod(@dtoo(%start)+!i-1)
%last = @otod(@dtoo(%start)+!i+!window-2)
smpl {%first} {%last}
' estimate equation - where the equation is P =c(1) + c(2)*P1(-1)
eq01.ls RES C RES(-1) RES(-24)
' store coefficients
colplace(coefmat,eq01.@coefs,!j)
' 1-period-ahead forecast
%24pers = @otod(@dtoo(%start)+!i+!window-1)
%24pere = @otod(@dtoo(%start)+!i+!window)
if @dtoo(%end) < @dtoo(%24pere) then 'check whether the forecast end point is greater than the workfile end point
exitloop
endif
' set smpl for forecasting period
smpl {%24pers} {%24pere}
' forecast with command *forecast* (see also *fit*)
eq01.forecast(f=na) yf
' set sampl to obtain the 24th period observation
smpl {%24pere} {%24pere}
' store forecasts
fcast = yf
smpl @all
show coefmat
show fcast.line
d(noerr) ser
The Yoyo
Postby The Yoyo » Mon Apr 10, 2017 8:36 am
Have you tried changing the parts:
' 1-period-ahead forecast %24pers = @otod(@dtoo(%start)+!i+!window-1) %24pere = @otod(@dtoo(%start)+!i+!window+23)
and then setting it the sample to
' set sampl to obtain the 24th period observation smpl {%24pers} {%24pere}
Not sure if that does what you are looking for.
umut
Postby umut » Tue Apr 11, 2017 7:06 am
Thank you very much "The Yoyo", it worked. I changed it to +22 instead of +23.
Alice Thai
Postby Alice Thai » Fri Apr 21, 2017 8:07 am
In my dissertation, I want to apply the rolling coefficient for 5-year window (my data is monthly so window size = 60), and step size = 1. Could someone please help me how can i perform the test for pooled panel data (consist of 8 countries) using fixed effect and GLS weight method is Cross section SUR. I am really grateful for any advice since I have such limited experience on Eviews and the deadline is near. Many thanks for your help.
The Yoyo
Postby The Yoyo » Fri Apr 21, 2017 8:28 am
What exactly are you looking for? Forecasts? Or just repeated GLS estimations?
It would be easier if you could provide the code you have written so far (or look for a example of a code in this forum).
Alice Thai
Postby Alice Thai » Fri Apr 21, 2017 8:49 am
Hi, I just want to repeat the estimation the see how the coefficient change over the tested period (from December 2002 to January 2017). Acctually I have no idea where to begin because this is the first time I come to Eviews and see this thread.
Alice Thai
Postby Alice Thai » Sat Apr 22, 2017 1:15 pm
This is my code so far, but when I press enter, a notification pops up "COEFMAT is not defined". What should I do in this situation? By the way, I want to show the rolling graph for my coefficent as well, what should I add in my code? Thank you.
'run rolling regression ' set window size !window = 60 ' set step size !step = 1 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq1 'calculate number of rolls !nrolls = @round((!length-!window)/!step) 'matrix to store coefficient estimates matrix(3,!nrolls) coefmat ' where 3 is the number of coefficients 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j=!j+1 ' set sample to estimation period smpl @first+!i-1 @first+!i+!window-2 ' estimate equation - where the equation is (SPOT(-1)-SPOT) = C (FORWARD-SPOT) eq1.LS(WGT=CXSUR) (SPOT(-1)-SPOT) C (FORWARD-SPOT) 'store coefficients colplace(coefmat,eq1.@coefs,!j) next show coefmat
The Yoyo
Postby The Yoyo » Sun Apr 23, 2017 1:18 am
You should set the "3" in the part that reads:
to the actual number of coefficients you estimate in your equation "eq1.LS(WGT=CXSUR) (SPOT(-1)-SPOT) C (FORWARD-SPOT)"
By the looks of it, it should be 2.
Alice Thai
Postby Alice Thai » Sun Apr 23, 2017 9:14 am
Thank you The Yoyo for the correction. However, when I press enter the code line !nrolls = @round((!length-!window)/!step) a message "!STEP is not defined". But i have defined !step = 1 on the above code. How can I solve this problem? Thank you so much.
The Yoyo
Postby The Yoyo » Sun Apr 23, 2017 9:45 am
Are you running the entire script as a program? (File>New>Program)? Don't run the code line by line in the top view bar.
(Or similary, running:)
'run rolling regression ' set window size !window = 60 ' set step size !step = 1 ' get size of workfile !length = @obsrange 'calculate number of rolls !nrolls = @floor((!length-!window)/!step) 'create series to store coefficients. We'll be running !nrolls regressions for 2 coefficients, so 2 series matrix(!nrolls,2) coefmat ' declare equation for estimation equation eq1 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j=!j+1 ' set sample to estimation period smpl @first+!i-1 @first+!i+!window-2 ' estimate equation - where the equation is (SPOT(-1)-SPOT) = C (FORWARD-SPOT) eq1.LS (SPOT(-1)-SPOT) C (FORWARD-SPOT) 'store the coefficient vector of this estimation in a matrix-row (transposing it first, for conveniency) rowplace(coefmat,@transpose(eq1.@coefs),!i) next show coefmat
Alice Thai
Postby Alice Thai » Sun Apr 23, 2017 1:02 pm
Dear The Yoyo, thank you so much, I am making progress on this, I have successfully created the rolling window. However, another problem arises since the result only displays around 250 observations (I have attached an image for the issue, I think this could be my data is pooled panel data so the program can only run smoothly for the 170 observations of the first country.). In addition, I want to estimate the change of the coefficients over the time series, so is there any way to display the year on the x-axis instead of the observations? Thank you for your help.
