Hello, I estimated the following multiple linear regression in Eviews:
Dependent Variable: LNPIBPC
Method: Least Squares
Date: 08/17/10 Time: 15:39
Sample: 1970 2000
Included observations: 31
C 6.666410 0.559503 11.91489 0.0000
Z 0.541974 0.056812 9.539794 0.0000
CC -0.944654 0.353005 -2.676033 0.0125
W 0.246999 0.044910 5.499807 0.0000
R-squared 0.839519 Mean dependent var 11.85432
Adjusted R-squared 0.821687 S.D. dependent var 0.308671
S.E. of regression 0.130343 Akaike info criterion -1.117385
Sum squared resid 0.458709 Schwarz criterion -0.932354
Log likelihood 21.31946 Hannan-Quinn criter. -1.057069
F-statistic 47.08124 Durbin-Watson stat 1.111689
Prob(F-statistic) 0.000000
And I'm doubting about the Durbin Watson statistic, I think is kind of low but to make a better analysis i've looked the RESIDUALS GRAPH (attached below) but I'm not sure i'm interpretating it well.
The "actual" and "fitted" curves are the ones of the regression right? And about the Residual curve, can i say it shows a serial correlation or not?
Thanks,
Moira
Serial correlation
moirapasseron
Serial correlation
- Residuals GRAPH
- Resids.jpg (37.02 KiB) Viewed 4878 times
Re: Serial correlation
With that Durbin-Watson you definitely have serial correlation.
moirapasseron
Is there any Eviews tool to fix the correlation? something about AR(1)?With that Durbin-Watson you definitely have serial correlation.
Thanks for your time
Yes, basically add ar(1) to the list of variables.
