There's a display problem with bar graphs
EViews Pamela
Re: There's a display problem with bar graphs
I imagine you are referring to things like the graph frame size, etc? Yes, this is something to be considered in the future.
Rafael.marcos
I don' t know qhy the graph that you paste wasn't wrong, I made the same steps as you did and I found something a little bit different:I don't think that's enough information.
If I open that group, then click on View->Graph, change the graph type to Area and select Stacked, I get the following:
Thanks Pamela.
PS: I'm just trying to show that the problem is recurrent also in area graphs.
- Area_graph.PNG (22.81 KiB) Viewed 7486 times
EViews Pamela
As I mentioned above, if you have the Excel-style bar graph option checked, and create an area graph, you will get incorrect results. I suspect this was the problem with your area graphs.
Rafael.marcos
Thanks Pamela.
I'm sorry I took so long to undestand. That was indeed my problem.
When there's no negative values the problem is 'solved'!! :D
Thanks!!!!
Rafael.
Thanks!!!!
Rafael.
That's right.I imagine you are referring to things like the graph frame size, etc? Yes, this is something to be considered in the future.
Rafael.marcos
Hi Pamela,Both bug fixes will be available via auto-update in the future.
I don't know how much I'm supposed to wait. But the bug wasn't fixed in the last update.
Is there any prediction of when the bug will be fixed? ( I just would like to know if I'm supposed to expect the problem to be solved by the end of the month, or any time soon)
Thanks.
Rafael.
EViews Pamela
The fix should be included in the next update.
Rafael.marcos
Hi Pamela.
I believe the recent update fixed the bug. At least the graphs that I created are now all correctly displayed.
Thanks a lot for your help. This was a small but annoying problem.
Have a great week.
Rafael.
Have a great week.
Rafael.
