Hi everyone, i´m very new in this program..... and probably my question is simple but i
I have a intraday data from 9:30 to 15:59, and i want to create 15-minutes intervals so i can see something like this: 9:30 9:45 10:00 ....
if someone could help me.... thanks!!!!!!!!!!
creating an interval sample
Re: creating an interval sample
You'll have to expand on what you mean by "create 15-minute intervals".
If you just want to create a new, empty, workfile with those intervals, you can do so by clicking on File->New->Workfile, and then setting the date specification to Intraday, etc...
i have this data, and i want to create a sample or a new page with 15 minutes intervals
8/01/1997 09:32 953.92
8/01/1997 09:33 953.60
8/01/1997 09:34 953.23
8/01/1997 09:35 952.76
8/01/1997 09:36 952.76
8/01/1997 09:37 952.55
8/01/1997 09:38 952.42
8/01/1997 09:39 952.42
8/01/1997 09:40 952.55
8/01/1997 09:41 952.77
8/01/1997 09:42 952.77
8/01/1997 09:43 952.87
8/01/1997 09:44 953.82
8/01/1997 09:45 955.05
8/01/1997 09:46 955.33
8/01/1997 09:47 955.05
8/01/1997 09:48 954.88
8/01/1997 09:49 954.78
8/01/1997 09:50 955.06
8/01/1997 09:51 955.16
8/01/1997 09:52 955.14
8/01/1997 09:53 955.18
8/01/1997 09:54 955.07
8/01/1997 09:55 954.94
8/01/1997 09:56 954.81
8/01/1997 09:57 954.65
8/01/1997 09:58 954.70
8/01/1997 09:59 954.65
8/01/1997 10:00 954.67
To create a new page, click on the New Page tab at the bottom of the workfile, then Specify by Frequency/Range, then set the structure type to "Dated-regular Frequency", then set the Frequency to Intraday, then fill in the rest.
ok.. i create the new page with te intervals and paste thhe data...... but the values are not ok... for example in the original data i have 955.05 at 9:45 and in the new page with 15 minutes intervals it chages to 954.96 and its the same with the other values....
ORIGINAL INTRADAY DAtA
8/01/1997 10:01 954.74
DATA WITH 15 INTERVALS8/01/1997 09:30 NA
8/01/1997 09:45 954.96
8/01/1997 10:00 950.13
8/01/1997 10:15 941.30
Thanks Again!!!!!
Thanks Again!!!!!
Again, what do you want the new data to be?
i just want to do some statistics with a 15 minutes intervals..... the problem is that i have minute by minute data and i´ve been trying to do it but... as i said before the numbers don´t match....
Is there anyway to convert my data from minute by minute to 15 minutes intervals???
thanks
thanks
Yes, but you need to specify how you want to do the "conversion". Do you want to average, to sum, and so on...
ahhhh ok... i just want the values as is.
for example my original data has
i want the same value for the 15 minute interval
sorry if i can´t explain myself...... thanks Gareth
it was with the first observation option.......
thanks a lot !!!!!!!!!!!!!!!!!!!!!!!!!
