Several Regressions
Several Regressions
Hi!
I'm new to eviews programming. I'm using Eviews 6.0
I would be very grateful if you could help me.I have been reading the manual "Command and Programming reference" but I´m mixed up over this. I'm working with ten series (returns of ten currencies). Each of them has near 3000 data.
I would need to make linear regression of each currency against each pair of the other nine currencies. Just to obtain the R2.
How can i program that?
Thanks a lot for your time and help.
Regards.
Regards.
Re: Several Regressions
Hi Puko,
if you name your 10 currency series as curr1, curr2, ..., curr10, is this what you mean? Hlp doc search: FOR LOOP, EQUATION, PROGRAM VARIABLES
for !i = 1 to 10
for !j = 1 to 10
equation eq_{!i}_{!j}.ls curr{!i} c curr{!j}
next Re: Several Regressions
Thanks!! I think so!! I will try later this evening!!
Thanks again!!
Thanks again!!
Might want to change the code slightly:
You might find it useful to read through the Programming Guide too.
for !i = 1 to 10
for !j = 1 to 10
if !i<>! then
endif
Thanks, but what i really want to make is several regressions with two regressors in each.
With this program
for !i = 1 to 10
for !j = 1 to 10
I obtain the regressions but with only one regressor.
I would like equations like this: .ls curr{!i} c curr{!j} curr{!z}
I have tried the following but there must be some mistakes. ¿Could you help me again please?
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
equation eq_{!i}_{!j}_{!z}.ls curr{!i} c curr{!j} curr{!z}
With this program
for !i = 1 to 10
for !j = 1 to 10
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
Indeed. Sorry! I better reply no posts should I do it too quickly and with mistakes.Might want to change the code slightly:
I have also tried with this program, but there are mistakes.
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
if !z=!y then
endif
Any idea please? Thanks.
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
if !z=!y then
endif
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
if !i<>!j and !i<>!z then
endif
Hi Gareth,
I had problems with you program, but at the end i have one that is working:
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
if !z=!j then
!k=1
else
endif
But now, i would like to extract only the R2 coefficients of each one of the regression. I have tried reading your Programming Guide and the example of R2 but i am not able.
Could you please help me?
Thanks again!!
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
if !z=!j then
!k=1
else
endif
Thanks again!!
Several Regressions
What have you tried and how did it not work?
With that, i get the problem "near singular matrix"
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
endif
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
endif
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
if !i<>!j and !i<>!z and !j<>!z then
endif
Thanks!! That one works perfectly!
Could you please help me getting only the R2 of these regressions?? That´s the last thing i would need.
Thanks again!!
Thanks again!!
Any help please to get only the R2 of the regressions from here.
Thanks!!
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
endif
Thanks!!
for !i = 1 to 10
for !j = 1 to 10
for !z = 1 to 10
endif
