How to get RSME(static&dynamic) with unit root test
bcdm3w
Postby bcdm3w » Thu May 20, 2010 9:49 am
Hello! I'm using the formal unit root test, and i had eviews find the optimal lag w/ max lag of 8. usually, i click 'forecast' to get the RSME of forecast errors for static and dynamic but i can't find the forecast button. Also, how do you make forecasts for the next four quarters using this unit root test?
Thanks so much!
Re: How to get RSME(static&dynamic) with unit root test
Postby EViews Gareth » Thu May 20, 2010 10:07 am
I'm not sure what you mean by forecast from a test.
bcdm3w
Postby bcdm3w » Thu May 20, 2010 10:47 am
For my homework, it says test for stationarity using formal unit root test. I had eviews find the optimal lag at 8 and my homework says, use the data from 1960 to 2000 to estimate various models and evaluate the out of sample forecasting ability. Does this mean that I actually have an AR(8) model and that I should estimate an equation of my response variable and AR(8) and then find the RMSE and forecast the rest of 2004?
Postby EViews Gareth » Thu May 20, 2010 11:03 am
Probably.
bcdm3w
Postby bcdm3w » Thu May 20, 2010 11:45 am
I forgot that Eviews gives you the augmented DIckey Fuller test equation and I think that's how you get the RMSE. But, how do i get forecasts for these models? I clicked 'forecast' and I am trying to use 2001:01- 2003:04 to make the forecasts for 2004 but eviews keeps saying N/A even after I apply the forecast.
