I have vecm model, unfortunately, I don't have enough knowledge on normality and classic assumption.
as long as I know, my model have problem in heteroscedasticity and autocorrelation, because the probability is lower than alpha that I use (5%). that's my first problem..
the second is: I'm using unit root test (ADF, level, none, lag=0) on the residual to justify that my mode is normal, is that process can be accepted?
please, any one give me suggestion on that... thanks before..
(urgent) normality and classic assumption in var/vecm
didik.pramusinto
didik.pramusinto
Re: (urgent) normality and classic assumption in var/vecm
There must be someone out there knowing the solution
Please share...
