please is there something like command or function for maximum in EViews? I mean a function that would out of e.g. 3 and -1 return 3. I hope it is. It's quite urgent. Thanks!!
Command / function for max (EV 6)
Re: Command / function for max (EV 6)
scalar max = x
if y>x then
max = y
endif
Gareth,
do you see any prompt way how to incorporate it into the following lines? I just need the !first, !second, !third be non-negative. I thought I would use a sort of max(!first, 0) function etc, but I see no obvious way how to implement your small code into the one below.
The current code may yield negative values, which is to be avoided. Don't take it personally, but I start to be tired from programming in EViews, I gave it a go, but I see that there is a limitation on each stupid step... it takes too much time and I just need to return to the forum with every trivial code line. Really disappointed, sorry for that.
for !index = 2 to 5
!first = !index - 1
!second= !index - 2
!third =!index - 3
matrix phi{!index} = phi{!first} * a1 + phi{!second} * a2 + phi{!third} * a3
Lots of ways to do it. You could copy my code directly in, replacing max,x,y and for your variables. Or something like:
No offense taken on your complaints. The EViews language can be a bit basic (ha, that's a pun - it was modeled after Basic originally!), and often requires some thinking to do something that might be simpler in other languages.
subroutine max(scalar !max, scalar !x, scalar !y)
!max = !x
if !y>!x then
!max = !y
endif
endsub
for !index = 2 to 5
!first = !index - 1
call max(!first,!first,0)
!second= !index - 2
call max(!second,!second,0)
!third =!index - 3
call max(!third,!third,0)
Actually, given your exact needs, a better way would be:
subroutine max0(scalar !x)
if !x<0 then
!x=0
endif
endsub
for !index = 2 to 5
!first = !index - 1
call max0(!first)
!second= !index - 2
call max0(!second)
!third =!index - 3
call max0(!third)
Gareth,
thanks for your suggestions. I will check them out. You are absolutely right by saying that EV simply requires more programming. I do not find myself any 'programmer' and I feel like trying to surpass own shadow... All this started because I cannot use custom identification in structural VAR... Many thanks, but I am afraid that a next problem will arise soon.
Gareth,
the latter code you posted works just marvellous. However, the problem is in reality more tricky:
I need to avoid a negatively indexed matrix to avoid error message,
but, more importantly I need to set the matrix itself, which yields a negative index, to zero.
In the code's last equation, phi matrices on right hand side act as weights to matrices a1, a2, a3. It is actually very important to distinguish between a "naturally zero index" and a "naturally negative index": Phi0 needs to be defined as indentity matrix. By contrast, the negative indexed phi matrices need to be set to zero.
I thought I could solve the problem by creating two subroutines. The first one is a copy paste of yours, but now it would set the index to 1000 instead of zero.
A second subroutine should recognize, whether a matrix name is 'phi1000'. If yes, it would set such a matrix to zero, otherwise it would keep the matrix untouched. I never take the chain of phi-s up to more than about 30, so it would be well recognizable.
This needs to be corrected as I am getting error message when I call it in this code:
Please if possible, I woud be very thankful for feedback to this. Thanks for encouragement today, I almost gave it up. For me programming is no easy.
subroutine set1000(scalar !x)
if !x<0 then
!x=1000
endif
endsub Code: Select all
subroutine setzero(matrix !mat)
if !mat = 'phi1000'
!mat = 0
endif
for !index = 2 to 5
!first = !index - 1
call set1000(!first)
call setzero(phi{!first})
!second = !index - 2
call set1000(!second)
call setzero(phi{!second})
!third = !index - 3
call set1000(!third)
call setzero(phi{!third})
next Re: Command / function for max (EV 6)
Please disregard my previous post. In the end, this worked:
I was not able to solve it without the help of Gareth. Many thanks!!
if !x<0 then
!x = 1000
endif
'create in the workfile matrix phi1000 with appropriate dimensions and zeros everywhere:
for !index = 2 to 5
!first = !index - 1
!second= !index - 2
!third =!index - 3
next Who is online
