SUR Coefficient Estimates
jti
Postby jti » Sun Dec 14, 2008 9:19 am
Good day to all,
I have a question regarding seemingly unrelated regressions (SUR).
I am trying to estitmate a SUR-Model for some financial indexes. For this reason, I already derived VAR residuals from some conventional macroeconomic time serieses (e.g. Term-Spread) as inputs (innovations) for the SUR-Model.
The System looks like the following example:
emerging_markets = c(1) + c(2)*world_market + c(3)*term
frontier_markets = c(4) + c(2)*world_market + c(3)*term
After creating a system and estimating it via the E-View's SUR fuctionality, I get the estimation output, of course, which works perfectly.
However my first question is, are the corresponding t-statistics robust estimates (autocorrelation and heteroscedasticity and which method does e-views use, Newey/West?), so that the inferences are statistically ok? Checking the residuals for serial correlation (Box-Pierce-Ljung Test and Durbin Watson), reveals significant correlations. Unfortunately testing for normality in the residuals, does reject the null.
My second question is, how I will be able to extract the coefficient estimates for the individual equations?
e.g. a table like the following
c c(2) c(3)
emerging markets 0,04 0,65 0,45
t-stats (2,01) (4,56) (1,72)
frontier_markets -0,01 0,32 -0,02
t-stats (-1,82) (2,03) (1,51)
Many thanks in advance.
Kind Regards,
Jan
houda
Re: SUR Coefficient Estimates
Postby houda » Wed Mar 04, 2009 6:54 am
hello
pleaaseeeeeeeeeeee i need your help pleaaase
i want to know how to use SURE estimetion in eviews
Postby startz » Wed Mar 04, 2009 7:44 am
Good day to all,
c c(2) c(3)
Kind Regards,
Jan
The standard errors correct for cross-equation correlation. They do not correct for heteroskedasticity or serial correlation.
Notice that in your example the same coefficient applies to world_market in both equations, but you show different estimates in your example table.
I don't believe EViews has a facility to format tables as you describe.
