Is it possible to obtain the seasonally adjusted series and/or seasonal components from the prophet forecasting procedure?
Thanks,
Erik
NIER Sweden
Seasonal components from prophet
Re: Seasonal components from prophet
Not currently, but I'll see if we can add a command line only feature to save them to disk so you can import the whole shebang, in the next patch.
Added a simple fullsave=filename option to command line prophet that will create a csv file on disk with the full prophet output.
Will be in next patch.
myseries.prophet(fullsave="c:/temp/prophetout.csv") myseries_f
Patch is out.
