I am Eviews 13 user.
I am working on creating a UI on top of Eviews using python.
for performance increase, i am trying to load data in UI from CSV file, which is prepared as :
1. I ran "show" statement with selective series in Eviews
2. data is displayed in table format,
3. Rt click on table, there is option "Save Table to Disk", where i select csv and save the selected output in csv file.
Now i want to achieve same from python code use Eviews Manager.
Is there any option or command by which the output of the show command can be saved in csv file.
I can call the same command in Eviews_app.run() method to solve the purpose.
Kindly help.
Save Eviews data in CSV file
Re: Save Eviews data in CSV file
Thanks Steve for you reply on this as :
I would recommend not using SHOW but instead use WFSAVE(type=text). To limit it to just a few series, add the @keep (or @drop) argument:
wfsave(type=text) output.csv @keep series1 series2
wfsave(type=text) d:\output.csv @keep crude_brent gdp_gr_*
Thanks it worked, but the first column is _date_ which has date (1990-01-01,) by default in csv.... i want it to be only year (1990).
How to do that.
Kindly help
How to do that.
Kindly help
Thanks, I finally got my answer from some earlier post and Eviews documentation as well.
Replying, if anyone is looking for such reference
It goes like :
alpha mydates = @datestr(@date, "YYYY")
wfsave(type=text) d:\output.csv byrow @keep mydates gdp_* @drop _date_
It goes like :
