How to find or check if an object is available/exists in a workfile?
JC198998
Postby JC198998 » Wed Jan 08, 2025 11:03 pm
I have a workfile with hundreds of objectives (graphs, equations, tables, etc). Is there a command (or line of code) I can run to open a certain object instead of having to look through the workfile each time?
Re: How to find or check if an object is available/exists in a workfile?
Postby EViews Steve » Thu Jan 09, 2025 8:13 am
Just select the correct workfile page (if there are multiple), then type in:
show x
to display the X object. If you type this into the Command window, you should see a dropdown after typing the first letter of the object name so you can pick from matching names.
Help page: show
To test if an object exists, use @isobject
JC198998
Postby JC198998 » Thu Jan 09, 2025 6:30 pm
It works, thank you!
