Dynamic instrumental variables in a system GMM
remuct
Postby remuct » Fri Jul 05, 2024 2:08 am
I would like to know how I can declare dynamic instrumental variables for a system of equations that I want to estimate using GMM. The tutorial indicates that for a single equation one can declare a dynamic instrument X by specifying @dyn(X) after the separator @. Can I do the same thing with systems? I tried :
system_name.gmm @ @dyn(x)
with different choices for x (gdp, spread,...) but I get the message "No instrument list specified"
Thank you for your advice
Re: Dynamic instrumental variables in a system GMM
Postby EViews Gareth » Fri Jul 05, 2024 2:51 am
Might be best to use the dialog wizard to specify your dpd, and then use the command capture to view the command line form.
remuct
Postby remuct » Fri Jul 05, 2024 6:05 am
Thank you for your response. However please forgive me, I couldn't really understand what I should do. What is meant by using the dialog wizard to specify my dpd, what does dpd refer to?
Postby EViews Gareth » Fri Jul 05, 2024 1:25 pm
Dynamic instruments are only available for dynamic panel data (dpd). Presumably that's what you're estimating?
