Not receiving all series requested from FRED db
bpuffer
Postby bpuffer » Thu Feb 22, 2024 1:41 pm
When using the following fetch command I only receive back the series beginning with "a":
fetch(db = FRED) ??BPPRIV
However, there are many more series available. If I Query the db directly for CTBPPRIV it shows it there.
This command does return all available series matching the criteria:
fetch(db = FRED) ??BP1FH
I am using Eviews 13 Standard Edition Jan 8 2024 Build
Re: Not receiving all series requested from FRED db
Postby EViews Gareth » Thu Feb 22, 2024 2:07 pm
Is this consistently happening? I just tried, and seemed to retrieve all?
bpuffer
Postby bpuffer » Fri Feb 23, 2024 6:57 am
...and this morning it's working fine. Sorry for the false alarm!
paolo.zanghieri
Postby paolo.zanghieri » Wed Mar 06, 2024 3:33 am
When I try to fetch FRED data I get an error message saying "Object reference not set to an instance of an object". I had this problem in the past, it appeared to have been solved when I installed thr latest (Jan 8) patch. Could you have a look?
Postby EViews Steve » Wed Mar 06, 2024 9:00 am
Please provide your FETCH command that is resulting in that error.
