Hi - I am estimating a two state Markov Switching VAR. Is it possible to compare IRF in State 1 versus State 2 as I am only seeing one set or response when graphed.
Thanks,
CNR
IRFs with MS-VAR
Re: IRFs with MS-VAR
Are your lag coefficients regime-specific? If they are not, then the impulse-responses are not regime-specific. If they are, then you will see a spool with the IRs for each regime.
Ah, I see. I had forgotten to tick the 'lagged endogenous' box. I am now seeing the two impulses.
Thanks for that Glenn!
