I am using Eviews 12 university edition and I have a question regarding estimation of SVARs. It seems that there are limitations in terms of the choices about the response standard errors. It seems I cannot choose the confidence intervals for some of the options (asymptotic, MonteCarlo, etc.). While trying other options, such as a confidence level of 70%, I got "Internal Error 505". This limitation was not listed in the advert for this edition.
Did anyone else ever experience this issue?
Kind regards,
Daniele
SVAR impulse response functions (methods and confidence level)
Re: SVAR impulse response functions (methods and confidence level)
Hello, i have the next simple code:
freeze(mode=overwrite, graph_ir1) var2.impulse(se=a, rep=1000, imp=struct) ciclo_eua ip_x_cc comex_cc dem_int_cc y_cc @ ciclo_eua
graph_ir1.addtext(t, font(20), [+/ b], Funciones de Impulso-Respuesta de un Shock del Ciclo de EUA)
We have 5 graph, how can change the title in each graphs?
Thank you..
Thank you..
I have a problem with the freeze function in svar. After obtaining the impulse responses with svar, I want to freeze the values in table format. However, when I write the freeze code (below), it freezes the graphs. What should I do to freeze the table values? Thanks in advance.
for !i=1 to 4
for !j=1 to 2
var var_!i_!j.ls 1 1 y!i x!j
var_!i_!j.append(svar) @VEC(F) = NA, NA, 0, NA
var_!i_!j.svar
freeze(var_!i_!j_f) var_!i_!j.impulse(24, a, imp=struct, se=a) @imp 1 2
