irrval
trubador
Did you use forum search?
irrval
Postby trubador » Thu Apr 30, 2015 3:01 pm
This thread is about irrval add-in.
The add-in allows you to compute internal rate of return for a series of cash flow. It makes use of the optimize feature of EViews, so will not work unless version 8 or higher is installed in your machine.
Please read the documentation for further instructions.
PS: Thanks to Javier (javiersan) for bringing up the issue and constructing the initial version of the estimation model.
Edit: As pointed out by dagfinnrime, there is a problem with output argument. Use "result" instead of "results" to store the final value of irr when calling the add-in from the command line.
Elena N.
Re: irrval
Postby Elena N. » Fri Jun 02, 2023 1:04 pm
Where can I download the irrval add-in? thank you
Re: irrval
Postby EViews Gareth » Fri Jun 02, 2023 2:26 pm
From the add-ins menu in EViews.
dagfinnrime
Contact:
Re: irrval
Postby dagfinnrime » Mon Dec 18, 2023 2:52 pm
1) if download irrval via the add-ins menu in EV13 you get the one-sided HP-filter add-in by the same author. You have to download the package from add-in list on web.
2) I don’t get the command-line versions to store results. It saves «status», but not the scalar result. The menu alternative works as expected.
Dagfinn
Return to “Add-in Support”
