How to save a graph to use as a template
jtfly08
Postby jtfly08 » Mon Nov 26, 2012 12:10 am
I am using Eviews 6.0. I created a graph with shaded recession periods. I want to save it as a template so that I can use it repeatedly. When I click the "Manage Predefined Template List", the "Template Management" window jump out. However, it seems I cannot do anything with this window because the "Add" option is disabled...What did I do wrong? Thanks!
Re: How to save a graph to use as a template
Postby EViews Gareth » Mon Nov 26, 2012 8:48 am
You have to name your graph before you can use it as a template.
jtfly08
Postby jtfly08 » Tue Nov 27, 2012 2:36 am
Yes, I get it. Thank you very much!
binhpham79
Postby binhpham79 » Tue Mar 12, 2019 3:01 am
Hi Gareth,
I wonder how to create a graph template by code.
Is it any named frozen graph can be used as a template? Because I see an option in dialog box but I do not find specific commands or relevant options in graph object methods.
Many thanks,
Postby EViews Jason » Tue Mar 12, 2019 9:36 am
There is currently no way to create/save a template by code. It must be done by the user interface. We will look into adding the feature to EViews 11
binhpham79
Postby binhpham79 » Tue Mar 12, 2019 4:37 pm
Many thanks. Hope to see this feature since it helps us when create irf plots from matrix. Applying a template saves a lot of codes.
BT454
Postby BT454 » Wed Feb 08, 2023 8:06 am
Tangentially related to this question:
Is it possible to apply a template to a graph programmatically?
Thanks!
Postby EViews Gareth » Wed Feb 08, 2023 10:13 am
Yes
BT454
Postby BT454 » Wed Feb 08, 2023 11:31 am
Thanks, I was looking through the programming guide and couldn't seem to find it. Could you please provide an example, or incorporate into the text below?
graph mgrus_0.line g_us_0
where g_us_0 is a group.
Thanks!
Postby EViews Gareth » Wed Feb 08, 2023 2:13 pm
