A problem in working with "FOR" Loop
eisamabodian
Postby eisamabodian » Thu Jul 14, 2016 5:41 am
i have problem, when i want to run this program:
for !k=-7 to 0 step 0.001 equation equ1.ls y c x*(x<=!k) x*(x>!k) m1 m2 m3 series ssr11(!k)=equ1.@ssr series kkk(!k)=!k next
this is a threshold model.i must save SSR and !k for each equation.
but negative index or decimal values are not acceptable as index for !k.
please help me.
Re: A problem in working with "FOR" Loop
Postby EViews Gareth » Thu Jul 14, 2016 8:14 am
What are you hoping to do with this:
Postby startz » Thu Jul 14, 2016 8:52 am
Make two vectors. Store the argument k in one and the result in the other. Then index by 1,2,3...
eisamabodian
Postby eisamabodian » Thu Jul 14, 2016 9:31 am
I want to save SSR of each equation and also !k values.
Postby EViews Gareth » Thu Jul 14, 2016 11:35 am
Yes, but what exactly are you doing with that line? Explain in words what it is doing.
eisamabodian
Postby eisamabodian » Fri Jul 15, 2016 2:01 am
I want to save SSRs of equations and also their correspondent !k.
In threshold regression approach i must sort these variables to obtain minimum
SSR and its correspondent !k.in this situation !k is threshold value for this equation.
Postby startz » Fri Jul 15, 2016 5:36 am
Make the loop for 1 to 700. Then calculate the corresponding k.
eisamabodian
Postby eisamabodian » Sat Jul 16, 2016 7:15 am
This loop has 7000 numbers not 700.Another problem is this loop is for negative numbers not positive.these numbers are decimal and negative.Unfortunately Eviews doesn't accept any negative or decimal number as index.How can I solve this problem?
Postby startz » Sat Jul 16, 2016 7:18 am
Make the index 1 to 7000. .Then store the values of k in one vector and the results you want in an other. Both indexed by 1 to 7000
eisamabodian
Postby eisamabodian » Sun Jul 17, 2016 2:22 am
How can I create an index from 1 to 7000?
But I need to build an index from -7 -6.999 -6.998 ........-0.003 -0.002 -0.001
Because step is 0.001
But the question is that how can I build an index from 7000 to 1 or vice versa ?Although as I said I need index in decimal form,but it seems that in Eviews we can not build indexes in decimal form.
Postby startz » Sun Jul 17, 2016 6:37 am
Roughly,
for i= 7000 to 1 step -1
k(i) = i/1000
ssr(i) = result
serkan
Postby serkan » Fri Jan 27, 2023 5:17 am
I have a problem with !x loop.
Since I have negative values in !x, I cannot produce outputs of val_{!s}_{!y}_{!x} for negative ones.
for !s=1 to 3
for !y=1 to 6
for !x=-6 to 12
series val_{!s}_{!y}_{!x} = @recode(sp{!s}=1, y{!y}({!x}), 0) 'It does not produce outputs for negative !x's.
As a solution, I tried to sum all !x values with a constant number (such as 10), but it did not work. Please see below;
series val_{!s}_{!y}_{!x+10} = @recode(sp{!s}=1, y{!y}({!x}), 0)
I will be happy if someone helps me.
Best
for !s=1 to 3 for !y=1 to 6 for !x=-6 to 12 series val_{!s}_{!y}_{!x} = @recode(sp{!s}=1, y{!y}({!x}), 0) 'It does not produce outputs for negative !x's. next next next series val_{!s}_{!y}_{!x+10} = @recode(sp{!s}=1, y{!y}({!x}), 0)
Postby EViews Gareth » Tue Jan 31, 2023 10:24 am
Its probably because series names can't have a negative sign in them, and you're using !x as part of the series name.
serkan
Postby serkan » Mon Feb 06, 2023 12:30 am
Yes it is.
Is there a solution to covert the name of the series while using negative values in !x loop? Like multiplying by -10? Or what do you recommend?
Postby EViews Gareth » Mon Feb 06, 2023 8:51 am
Simplest is to use the @makevalidname function.
