Hello, I was running non-linear least squares and I got an overflow.
Since then, all other maximization routines that were estimating other equations (and were working before the overflow) got stuck and I kept on obtaining overflows also in equations that i was able to estimate without any problems.
I guess that the overflow affects the maximization routines overall... so my question is if there is a way to restart the routines in order to get rid of the problem caused by the overflow.
Thank you!
getting out of an overflow
Re: getting out of an overflow
You probably want to change the starting values (in the C vector).
yes... indeed!
the starting values are those appearing in the vector c?
should I go to the vector c and change one by one the values?
lukeroom wrote:yes... indeed!
It's very hard to know which starting value is causing the problem. You might want to set them all at values you think are reasonable. If that doesn't work then, yes, experimenting with the values makes sense.
very useful, thank you! Finally I know where starting values are stored.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 14 guests
