Is there a way to reference a program line?
dravenous
Postby dravenous » Wed Aug 31, 2022 1:49 pm
Hi I'm looking for something that will paste the line number in a logmsg. I've been manually doing "logmsg Line X" but would love if there's some sort of @line command I'm not aware of because if I write additional program lines obviously my manually entered "Line X" will be incorrect. Mostly for debugging code.
Thank you!
DR
Re: Is there a way to reference a program line?
Postby EViews Gareth » Wed Aug 31, 2022 3:26 pm
There isn't :(
Postby EViews Jason » Thu Sep 08, 2022 5:50 pm
With the latest EViews 13 patch, in addition to the 'program' option to logmode.
logmode program
you can add the options 'file', 'filepath' and/or 'linenum', where:
'file ' will prepend the filename of the program to the program line
'filepath' will prepend the filename and path to the program line
'linenum' will prepend the line number of the program line
For example,
logmode program linenum file
will enable program line logging and include the file name and line number with each log entry.
