Error "Variable is not defined" in panel ARDL
Re: Error "Variable is not defined" in panel ARDL
Postby EViews Gareth » Fri Feb 25, 2022 6:52 pm
The data in excel should contain numbers only - yours has letters too.
academia1
Postby academia1 » Fri Feb 25, 2022 7:55 pm
I input the Excel file with the figures only and applied the model:
GDP = β1 + β2 FDI + β3 ODA + u
The same error that the "GDP is not defined" appeared.
Below is the data in Excel without the characters but only the figures.
I am using a Demo version of Eviews.
Should I input another function without the coefficients like above? Thks.
Postby EViews Gareth » Fri Feb 25, 2022 8:19 pm
The screenshot of the Excel file shows that there are letters in the cells (the word "billion").
The screenshot of EViews workfile confirms that out of the 4 series that were imported, only one contains numbers (series01).
The screenshot of EViews workfile also confirms that there are no series called "GDP" in your workfile.
academia1
Postby academia1 » Mon Feb 28, 2022 7:22 pm
Problem solved. Thank you.
