An introduction to EViews programming.
Re: An introduction to EViews programming.
xxx
You could use a for loop to loop through the variables. But if you've already written it out like that, it might be simpler to just leave it as is.
The wfopen command has a "range=" argument to specify the Excel range.
How to use loop if I am going to use that for a series in a workfile?
I have no idea what you're asking.
Hi All
This post is in reference to an earlier post, but I wasn't sure how to reply to that.
I am trying to create a for loop that loops through a group of variables, and then runs an auto ARMA process through each individual equation. The auto ARMA is quite basic, and the loop begins to run, but after two variables it just keeps re-iterating and it will not solve.
Here is the for loop for referring to the group, where gexp is the name of the group:
Would this be a data issue? I tried removing the problematic variable but it still encounters the same issue. Here is the auto ARMA code, which follows straight after above:
Thanks for your help!
pageselect experiment
delete *
smpl 1980m1 2016m12
'read(b2, s=top_ten) {%pathread}\correl_first.xls range=B2
'wfopen {%pathread}\correl_first.xls range=B2
import {%pathread}\correl_first.xls range=A2
group gexp *
for %zz resid c
gexp.drop {%zz}
'copy *
for !j=1 to gexp.@count
%var = gexp.@seriesname(!j)
%eqname = "arma" 'name of equation object that will be used.
'%dep = "y1_ind" 'dependent variable
%maxAR = "5" 'maximum number of AR terms
%maxMA = "5" 'maximum number of MA terms
%regs = "C " 'independent variables
%criterion = "@schwarz" 'which criterion to use enter "@AIC" for Akaike, "@schwarz" for Schwarz, and @HQ for Hannan-Quinn
!maxAR = @val(%maxAR)
!maxMA = @val(%maxMA)
close {%eqname}
'create table for storing critical values.
%matname = "crits"
if @isobject(%matname) then
%matname = "__crits"
delete {%matname}
endif
endif
table(!maxar+2,!maxma+2) {%matname}
{%matname}(1,1) = "AR / MA"
{%matname}.setlines(1) +b
{%matname}.setlines(a) +r
'set sample
smpl @first+!maxAR @last
!mincrit = 1e12 'set the minimum to an artificially large value to begin
'estimate the models
%arstring = ""
for !i=0 to !maxar
'build up string for AR terms.
if !i>0 then
%arstring = %arstring + " ar(" + @str(!i) + ")"
endif
%mastring = ""
for !j=0 to !maxma
'build up string for MA terms
if !j>0 then
%mastring = %mastring + " ma(" + @str(!j) + ")"
endif
'estimate equation
smpl 1980m1 %end
equation {%eqname}.ls dlog({%var}) {%regs} {%arstring} {%mastring}
'capture criterion
if @upper(%criterion) = "@AIC" then
!crit = {%eqname}.@aic
endif
if @upper(%criterion) = "@SCHWARZ" then
!crit = {%eqname}.@schwarz
endif
if @upper(%criterion) = "@HQ" then
!crit = {%eqname}.@hq
endif
'compare criterion
if !crit < !mincrit then
!mincrit = !crit
!bestAR = !i
!bestMA = !j
%bestARstr = %arstring 'store the best ar string
%bestMAstr = %mastring 'store the best ma string
{%matname}.settextcolor(@all) black 'table formatting.
!ii=!i+2
!jj=!j+2
{%matname}.settextcolor(!ii,!jj) red
endif
{%matname}(!i+2,!j+2) = !crit
{%matname}(!i+2,1) = !i
{%matname}(1,!j+2) = !j
equation {%eqname}{%var}.ls dlog({%var}) {%regs} {%bestARstr} {%bestMAstr}
'show {%eqname}
'show {%matname}
smpl 2002m1 %forend
{%var} = @nan({%var},0)
smpl if {%var} = 0
{%eqname}.forecast {%var}_f
series MAPE_{%var} = @rmse({%var},{%var}_f)
smpl %beg %forend
'plot @pca({%var}_f) @pca({%var})
group g1_f *_f
group g1_mape mape_*
write {%pathwrite}\res_poolbrid_sam.xls g1 g1_f g1_mape
Dear friends, how to generate two series
Xt=2.2+0.6*Xt-1+0.3*Xt-2+e
Yt=0.5+0.3*Yt-1-0.6*Yt-2+e
where e is white noise, with using rndseed 3006?
Please help
Please help
What have you tried so far and where are you stuck?
You have two "for" statements and only one "next"
Hi, I would like to run OLS for 63 time series variables based on 3 explanatory variables with lags depending on the best AIC.
I tried some of previous programs from this forum, but it does not work. It writes: For statement unterminated in "FOR !J=1 TO 4"
Thank you very much for you help. best regards, Jara
!aic = 99999999
!maxlags = 4
!bestlag = 0
smpl @first+!maxlags @last
matrix(15,63) coefs
for !j=1 to !maxlags
for !i=1 to 63
equation eq{!i}.ls y{!i} c y{!i}(-1 to -!j) x(0 to -!j) z(0 to -!j)
if eq.@aic < !aic then
!bestlag = !j 'if this lag specification has the best AIC, then store this lag as !bestlag.
!aic = eq{!i}.@aic
endif
colplace(coefs, eq{!i}.@coefs, !i) 'store coefficients into matrix
You have two for statements but only one next statement. You need another one.
ups. thank you.
it works now, but it seems to me strange that all 63 regressions have full 4 lags for all explanatory variables ...
and is there any easy way how to download the matrix with the p-values? I used to use
thank you very much for your help.
!aic = 99999999
!maxlags = 4
!bestlag = 0
for !i=1 to 63
equation eq{!i}.ls cz_{!i} c cz_{!i}(-1 to -!j) ugap(0 to -!j) fx(0 to -!j) vatup vatdown
if eq{!i}.@aic < !aic then
!aic = eq{!i}.@aic
endif
matrix(17,63) coefs ' at the beginning
colplace(coefs, eq{!i}.@coefs, !i) ' at the FOR statement after the regression
use eq.@pvals rather than eq.@coefs
Thnk you very much Gareth ..
Writing a text message to the output file
I want to write a text message to the output file :
output(t) c:\out.txt
text message
ls x1 c x2
Could you please help? I tried to use logmsg and logsave to the above output file. However, only regression result is written to the output file, but not the text message.
Thank you very much, Horward
text message
ls x1 c x2
how to programming pairwise convergence test?
I need your help with programming pairwise convergence test code the test is developed by Peseran (2007) and Phillips and Sul (2007).
Is Is there an inbuilt program in eviews to do this and if it has to be done for a large number of pairs how to write the loop for this?
Best Regards,
APS
Best Regards,
APS
Users browsing this forum: No registered users and 21 guests
