How to use "_this"
For tips, questions and general information about writing Add-ins, how to package them, and how to submit them to EViews for publication.
EViews Esther
How to use "_this"
Postby EViews Esther » Wed Dec 01, 2010 2:32 pm
EViews 7.1 provides a new keyword _this which refers to the currently active object.
To illustrate the main idea, suppose that we have a series “x” which contains all ones:
series x = 1
[E.g.1] _this can refer to the object that you lastly clicked on.
If you click on “x” in the workfile, _this denotes the “series” object.
Note that _this can be any object (such as coef, equation, group, etc.) you will choose in your workfile.
[E.g.2] When used in a program, _this refers to the active object at the time the program was initiated.
In particular, suppose we have the trivial (silly) program Myline.prg which consists of the command:
_this.line
If you run this program, you will see the line for the series “x”.
Now, let us add the following lines (in Myline.prg):
_this.line series y = 2 _this.line
Do you see the line for the series “y”? No. :wink: We still see the line for the series “x” because _this refers to the initially opened object.
CrisisStudent
Re: How to use "_this"
Postby CrisisStudent » Wed Apr 14, 2021 12:41 am
Can one use _this command in some way to give name to the corresponding object if it is unnamed?
My situation is following: I have add-in that uses the name of _this (i.e. _this.@name) in its procedures. However, when the object is unnamed then _this.@name will return empty string, which then will lead to failure of the add-in (this can of course happen only in GUI execution). What I would need is to have a way to set the name of the unnamed object so that the add-in can proceed.
Postby EViews Gareth » Wed Apr 14, 2021 8:08 am
Unfortunately not - there is no way to name an unnamed object. That's why _this is provided.
CrisisStudent
Postby CrisisStudent » Wed Apr 14, 2021 8:19 am
Thanks Gareth. Makes sense. I just ended up adding check if the name is empty, and using '"_this" if yes, so it is not a big deal in the end.
Return to “Add-in Writing area”
