Dummy Variable (near matrix error)
rafrods
Postby rafrods » Mon Apr 05, 2021 5:44 pm
Hello. I am estimating a regression between the GDP and social spending of municipalities and I am trying to insert a dummy variable for municipalities in the metropolitan region (municipalities in the metropolitan region = 1; municipalities outside the metropolitan region = 0). But Eviews is displaying the near matrix error message when I use a panel regression for fixed effects or random effects, and when I select neither effect, the error message does not appear. However, when I analyze the correlation matrix, it is clear that there is no perfect correlation between the dummy variable and the other variables in the equation. What could be causing this error?
Re: Dummy Variable (near matrix error)
Postby EViews Gareth » Mon Apr 05, 2021 5:49 pm
Run this code:
wfcreate u 100 series y=@nrnd series x1=@nrnd series x2=@nrnd series x3 = x1+x2 group g x1 x2 x3 show g.corr equation eq1.ls y c x1 x2 x3
rafrods
Postby rafrods » Mon Apr 05, 2021 6:28 pm
Hello Garreth, can I ask you two questions? The first is that I noticed, and edited my post, that the message near matrix error appears when I use a panel regression for fixed effects or random effects, but not when I select neither effect (effects specification; cross -section; none).
The other question is whether you could translate this command, considering that y = GDP; x1 = leducation; x2 = lhealth; and the dummy variable = dummyGV
Thank you for your attention
