looping through an alpha series
amrsherif
Postby amrsherif » Wed Feb 03, 2021 3:33 pm
This seems very basic, but i am unabnle to loop through the elements of an alpha series.
I have an alpha series with names of series that i want to fetch.
How can i loop through them so i can add them to a string?
See attached photo for an example of what the series looks like
I have tried:
1) for %series in alpha_series_name
2) for !i=1 to @ilast(alpha_series_name)
3) i've also converted it into an svector but could still not access the elements in that
EViews Matt
Re: looping through an alpha series
Postby EViews Matt » Wed Feb 03, 2021 4:55 pm
If what you're ultimately after is a string containing the data in an alpha series, you can generate that with a single expression,
%names = @wjoin(@convert(alpha_series_name))
Otherwise, if you actually need to loop through the alpha series to perform other work, you can in a number of ways. For example, looping over observations,
for !i = @ifirst(alpha_series_name) to @ilast(alpha_series_name) ... alpha_series_name(!i) ... next
Or by looping over an equivalent svector,
svector tmp stom(alpha_series_name, tmp) for !i = 1 to @rows(tmp) ... tmp(!i) ... next
amrsherif
Postby amrsherif » Thu Feb 04, 2021 6:17 am
This is strange, I have looped through alpha series many times before, but i cannot get this one to work.
I have tried this:
svector tmp
show tmp(!i)
No luck
TMP(1) is not defined in show tmp(1)
WHen i tried this:
show alpha_series_name(!i)
it loops through the numbers, but it lags the series by the index, instead of giving the ith element
amrsherif
Postby amrsherif » Thu Feb 04, 2021 6:22 am
I figured it out.
It works when i convert the ith element into a string or temporary string, then use it
EViews Matt
Postby EViews Matt » Thu Feb 04, 2021 8:13 am
Right, the show command is predominantly used for displaying entire objects rather than individual elements. As such, ( ) notation is interpreted as lag notation rather than element-of notation. Any normal non-genr expression works as intended, as you discovered.
