Animate using code with Eviews 12
ErikG
Postby ErikG » Wed Dec 30, 2020 5:43 am
Hi and thanks for the new features in Eviews 12.
Is it possible to create and store animations using code?
I see in the code capture window that the code should be something like:
series01.animate(fps=4, ans="1971m01", ane="2030m12", ar=11, ai=12,anim=mov)
But when used in a prg file I get a message that animate is not a valid series view.
If the animate command is applied to a graph object instead I get internal error 501.
Happy new year!
/Erik
Re: Animate using code with Eviews 12
Postby EViews Jason » Wed Dec 30, 2020 2:19 pm
Better error messages will be added in the next patch.
Since the 'animate' proc does not exist for series, it will be removed from command capture. It will only be available in graphs and geomaps.
